I have a Dust sensor and GrovePi+ and I would like to translate the measure unit from pcs/0.01cft to ug/m^3.
I have used the code from grove_dust_sensor.py
try:
[new_val,lowpulseoccupancy] = grovepi.dustSensorRead()
if new_val:
print lowpulseoccupancy
time.sleep(5)
the value of lowpulseoccupancy is already in pcs/0.01cft ?
lowpulseoccupancy is the number of ms in a 30 second period for which the sensor data was low which indicates a reading from the dust sensor. If you check the wiki here: http://www.seeedstudio.com/wiki/Grove_-_Dust_Sensor, to change that into concentration just do this: ratio = lowpulseoccupancy/(sampletime_ms10.0) # Integer percentage concentration = 1.1pow(ratio,3)-3.8pow(ratio,2)+520ratio+0.62 #using spec sheet curve
The datasheet says the concentration is in .01CF which is 283ml or 1 cubic feet. 1 cubic feet is 0.0283168cubic meter so you can just use a multiplying factor to convert it from cubic feet to cubic meter.
