Karan,
Here is the log for troubleshooting GrovePi:
Check space left
/dev/root 7.3G 2.7G 4.3G 38% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 12M 420M 3% /run
/dev/mmcblk0p1 3.7G 21M 3.7G 1% /boot
tmpfs 87M 0 87M 0% /run/user/1000
/dev/sda1 60M 16K 60M 1% /media/pi/boot
Check for dependencies
python-rpi.gpio 0.6.2~jessie-1 install ok installed
arduino 2:1.0.5+dfsg2-4 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.32
Raspberry Pi Details:
Type: Pi 2, Revision: 01, Memory: 1024MB, Maker: Embest
- Device tree is enabled.
- This Raspberry Pi supports user-level GPIO access.
-> ie. export WIRINGPI_GPIOMEM=1
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 006: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 005: ID 0781:5567 SanDisk Corp. Cruzer Blade
Bus 001 Device 004: ID 04ca:0061 Lite-On Technology Corp.
Bus 001 Device 007: ID 1a2c:0c21 China Resource Semico Co., Ltd
|__ Port 2: Dev 7, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 2: Dev 7, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 5, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 5: Dev 6, If 0, Class=Vendor Specific Class, Driver=rt2800usb, 480M
Raspbian for Robots Version
V 6.9
This version of Raspbian was modified by Dexter Industries on the Jessie Raspbian Build.
This version was updated on 2016.03.20
Hostname
dex
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0’ or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version
GrovePi has firmware version: 1.2.2
