I’ve modified my own simplebot to use a grabber arm and ultrasonic sensor. I’ve placed the raspberry pi camera above the grabber arm but I am unable to “call” the camera using a keyboard entry.
Basically I want to nest the function that is performed by
within the code below:
        inp = stdscr.getkey() #Take input from the terminal
        #Move the bot
        if inp == 'w':
                fwd()
                print("fwd")
        elif inp=='a' :
                left()
                print("left")
        elif inp=='d':
                right()
                print("right")
        elif inp=='s':
                back()
                print("back")
        elif inp=='x':
                stop()
		print("stop")
	elif inp =='p':
        	try:
            		value = BP.get_sensor(BP.PORT_1)
            		print(value)
        	except brickpi3.SensorError as error:
            		print(error)
        	time.sleep(0.02)
	elif inp=='g':
		grip()
		print("grip")
	elif inp=='r':
		rgrip()
		print("release grip")
	elif inp =='q':
		BP.reset_all()
So, ideally, when I press “c” I could pull up the camera video for 5 seconds? Is there an easy way to achieve this goal?
Thanks in advance for any tips.
