EasyGoPiGo3 C++ API passed tests
“Co-developed with AI” code is sometimes a term for AI slop, or a developer attempting to use the current AI tools to assist productivity.
Four years ago I worked for a month on developing the drive_cm() EasyGoPiGo3 C++ API and gave up.
A week ago, I asked Claude to use the DI/MR developed class GoPiGo3 C++ API and translate the Python EasyGoPiGo3.py to EasyGoPiGo3.cpp and respective header file EasyGoPiGo3.h ignoring the sensor imports and convenience sensor methods.
In one evening of a couple turns pointing out errors and adding additional constraints, I had a preliminary EasyGoPiGo3 C++ API ready for deep review. Additionally, I asked Claude to prepare a testEasyGoPiGo3.cpp to test the new C++ EasyGoPiGo3 API. Adding these files to the build process, started a week of test program review and tuning, EasyGoPiGo3 API testing, and API documentation.
I am pleased to announce my “without sensors” EasyGoPiGo3 C++ API methods have passed testing.
EasyGoPiGo3 C++ API
    C++ port of EasyGoPiGo3 Python library
    Sensor functions for distance sensor, IMU, etcetera are intentionally excluded.
    using RGBColor = tuple(uint8_t R, uint8_t G, uint8_t B)
    Class EasyGoPiGo3(string config_file_path): public GoPiGo3
      config_file_path defaults to ~/.gpg3_config.json
      Inherits all GoPiGo3 instance vars and methods
      Instance Vars:
        int speed: default 150 DPS
        tuple RGBColor left_eye_color:   (uint8 R, uint8 G, uint8 B)
        tuple RGBColor right_eye_color:  (uint8 R, uint8 G, uint8 B)
        left_encoder_target
        right_encoder_target
IMPLEMENTED METHODS:
(Methods maked with P were tested by test_EasyGoPiGo3.cpp and deemed to "PASS")
 P      void  set_speed(int speed_in_DPS=150)
 P      void  reset_speed():  reset speed to DEFAULT_SPEED (300 DPS)
 *      int   get_speed()
 *      void  forward(): drive forward - use set_speed() or default: 150 DPS
 *      void  backward(): drive backward
 *      void  stop():   stop both motors, power off to let wheels float
 P      void  drive_cm(float dist, blocking=true): dist in cm
 P      void  drive_inches(float dist, blocking=true): dist in inches
 *      void  right() : pivot cw around right wheel
 *      left  left():  pivot ccw around left wheel
 *      void  spin_right(): spin in place clockwise
 *      void  spin_left(): spin in place counter-clockwise
 P      void  steer(int left_percent, int right_percent):  -100 to +100
 P      target_reached(left_tgt_degrees, right_tgt_degrees):  use to detect when to stop
                                                              forward(), backward(), right(), left(), spin_right(), spin_left()
                                                              and for non-blocking drive_cm() or drive_inches()
 P      void reset_encoders(bool blocking = true): resets both encoders to 0,
                                                   if blocking=true waits till both motors have stopped
 P      pair(int32_t, int32_t) read_encoders(string& units = "cm") returns (left,right) encoder in degrees or converted to a distance
                                                     units: {"cm","in","inch","inches","raw")
                                                     "raw" causes encoder degree average for both left and right
 P      float read_encoders_average(units = "cm") returns average of left and right encoders in degrees or optionall convert to distance
 P      void drive_degrees( float degrees, bool blocking=true): drive by turning each wheel degrees
 P      void turn_degrees(in:deg, blocking=true):  left: negative degrees
 P      void orbit(float degrees, float radius_cm = 0.0f, bool blocking = true)  Orbit with radius to center of GoPiGo3
 P      float volt();  return battery voltage as float
 P      void blinker_on(int id)   0=Left,1=Right
 *      void blinker_off(int id)  0=Left 1=Right
 *      void blinker_on(string&  id)   "left" or "right"
 P      void blinker_off(string& id)   "left" or "right"
 P      void led_on(int id)        alias for blinker_on
 *      void led_on(string& id)    alias for blinker_on
 P      void led_off(int id)       alias for blinker_off
 *      void led_off(string& id)   alias for blinker_off
 P      void set_left_eye_color(RGBColor& color)
 P      void set_right_eye_color(RGBColor& color)
 P      void set_eye_color(RGBColor& color)    set both left and right to same color
 P      void open_left_eye()   turn on left eye  (to the stored left eye  color)
 P      void open_right_eye()  turn on right eye (to the stored right eye color)
 P      void open_eyes()       turn on both right and left eyes (with respective stored color)
 P      void close_left_eye()  turn off left eye programmable LED
 P      void close_right_eye() turn off right eye programmable LED
 P      void close_eyes()      turn off both right and left programmable "eye" LEDs
INHERITED METHODS (GoPiGo3.h)
 P      class GoPiGo3 GoPiGo3()
    // Instance Variables
    float WHEEL_BASE_WIDTH         = 117;     // default distance (mm) from left wheel to right wheel.
    float WHEEL_DIAMETER           = 66.5;    // defautl wheel diameter (mm)
    float WHEEL_BASE_CIRCUMFERENCE = WHEEL_BASE_WIDTH * M_PI;  // pi from cmath
    float WHEEL_CIRCUMFERENCE      = WHEEL_DIAMETER   * M_PI;  // pi from cmath
    int   MOTOR_GEAR_RATIO         = 120;
    int   ENCODER_TICKS_PER_ROTATION = 6;  // default GoPiGo3 has 6 ticks, 16 ticks if in .gpg3_list_of_serial_numbers.pkl file
    float MOTOR_TICKS_PER_DEGREE     = ((MOTOR_GEAR_RATIO * ENCODER_TICKS_PER_ROTATION) / 360.0);  // ticks per degree of wheel shaft rotation
P   int     detect(bool critical = true) // Confirm that the GoPiGo3 is connected and up-to-date
P   int     get_manufacturer(char *str)  // Get the manufacturer (should be "Dexter Industries")
P   int     get_board(char *str)         // Get the board name (should be "GoPiGo3")
P   int     get_version_hardware(char *str)  // Get the hardware version number
P   int     get_version_firmware(char *str)  // Get the firmware version number
P   int     get_id(char *str)            // Get the serial number ID that is unique to each GoPiGo3
P   bool    check_serial_number_for_16_ticks(std::string serial_file_path="~/.gpg3_list_of_serial_numbers.pkl")  // true if in file
P   int     load_robot_constants(std::string config_file_path="~/.gpg3_config.json")  // Load (or set if no file)
    int     save_robot_constants(std::string config_file_path="~/.gpg3_config.json")  // Save (to JSON file)
    int     set_robot_constants(float wheel_diameter, float wheel_base_width, int ticks, int motor_gear_ratio)  // Set new robot values and dependent constants
    int     set_led(uint8_t led, uint8_t red, uint8_t green = 0, uint8_t blue = 0)  // Control the LED
  // Get the voltages of the four power rails
    // Get the voltage and return as floating point voltage
    float   get_voltage_5v     ();
    float   get_voltage_battery();
    // Pass the pass-by-reference float variable where the voltage will be stored. Returns the error code.
    int     get_voltage_5v     (float &voltage);
    int     get_voltage_battery(float &voltage);
  // Set a servo position in microseconds
    int     set_servo(uint8_t servo, uint16_t us);
  // Set the motor PWM power
    int     set_motor_power(uint8_t port, int8_t power);
  // Set the motor target position to run to (go to the specified position)
    int     set_motor_position(uint8_t port, int32_t position);
  // Set the motor speed in degrees per second.
    int     set_motor_dps(uint8_t port, int16_t dps);
  // Set the motor PWM and speed limits. PWM limit applies to set_motor_position and set_motor_dps and speed limit applies to set_motor_position.
    int     set_motor_limits(uint8_t port, uint8_t power, uint16_t dps);
  // Get the motor status. State, PWM power, encoder position, and speed (in degrees per second)
    int     get_motor_status(uint8_t port, uint8_t &state, int8_t &power, int32_t &position, int16_t &dps);
  // Offset the encoder position. By setting the offset to the current position, it effectively resets the encoder value.
    int     offset_motor_encoder(uint8_t port, int32_t position);
  // Get the encoder position
    // Pass the port and pass-by-reference variable where the encoder value will be stored. Returns the error code.
    int     get_motor_encoder(uint8_t port, int32_t &value);
    // Pass the port. Returns the encoder value.
    int32_t get_motor_encoder(uint8_t port);
    // Set ecoder value to 0
    int     reset_motor_encoder(uint8_t port);
  // Configure grove pin(s)/port(s)
    // Set grove port type
    int      set_grove_type(uint8_t port, uint8_t type);
    // Set grove pin(s) mode
    int      set_grove_mode(uint8_t pin, uint8_t mode);
    // Set grove pin(s) output state. LOW or HIGH (0 or 1).
    int      set_grove_state(uint8_t pin, uint8_t state);
    // Set grove pin(s) PWM duty cycle. 0-100% with 0.1% precision.
    int      set_grove_pwm_duty(uint8_t pin, float duty);
    // Set grove port(s) PWM frequency. 3 - 48000 Hz
    int      set_grove_pwm_frequency(uint8_t port, uint16_t freq = 24000);
  // Perform an I2C transaction
    int      grove_i2c_transfer(uint8_t port, i2c_struct_t *i2c_struct);
  // Start an I2C transaction
    int      grove_i2c_start(uint8_t port, i2c_struct_t *i2c_struct);
  // Read grove value(s)
    int      get_grove_value(uint8_t port, void *value_ptr);
  // Read grove pin state
    // return value
    uint8_t  get_grove_state(uint8_t pin);
    // get value with pass-by-reference, and return error code
    int      get_grove_state(uint8_t pin, uint8_t &value);
  // Read grove pin voltage
    // return floating point voltage
    float    get_grove_voltage(uint8_t pin);
    // get floating point value with pass-by-reference, and return error code
    int      get_grove_voltage(uint8_t pin, float &value);
  // Read grove pin raw ADC analog value
    // return the value
    uint16_t get_grove_analog(uint8_t pin);
    int      get_grove_analog(uint8_t pin, uint16_t &value);
  // Reset the grove ports (unconfigure), motors (float with no limits), and LEDs.
    int     reset_all();
Source and header at:
That’s awesome!
Claude is also a great way to learn new things. I’ll admit to using it, but reviewing every line of code. It’s almost as intensive as writing those lines myself, but Claude will catch more cases and generally give me better code.
