When I run any script (even firmware_version_test.sh), I get the following error: ‘int’ object has no attribute ‘getitem’
And ic2 test I get:
Error: Could not open file /dev/i2c-0’ or/dev/i2c/0’: No such file or directory
I tried updating the firmware from the desktop icon, and it was successful, but I still get the error.
Here is the output from all_tests.sh:
GrovePi Troubleshooting Script
Adding permissions to the scripts
Check space left
/dev/root 3.6G 2.9G 440M 88% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 6.2M 425M 2% /run
/dev/mmcblk0p1 63M 21M 43M 33% /boot
tmpfs 87M 4.0K 87M 1% /run/user/1000
Check for dependencies
arduino 2:1.6.0 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Raspberry Pi Details:
Type: Pi 3, Revision: 02, Memory: 1024MB, Maker: Embest
- Device tree is enabled.
*–> Raspberry Pi 3 Model B Rev 1.2 - This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
|__ Port 3: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
Raspbian for Robots Version
V 7.0
This version of Raspbian was modified by Dexter Industries on the Wheezy Raspbian Build.
This version was updated on 2016.10.05
Hostname
dex
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version
File “/home/pi/Dexter/GrovePi/Software/Python/grove_firmware_version_check.py”, line 40, in
print(“GrovePi has firmware version: %s” %grovepi.version())
File “/home/pi/Dexter/GrovePi/Software/Python/grovepi.py”, line 265, in version
return “%s.%s.%s” % (number[1], number[2], number[3])
TypeError: ‘int’ object has no attribute 'getitem’
Log has been saved to Desktop. Please copy it and send it by email or upload it on the forums
