Hi everyone!
I have a problem with my GoPiGo and I will try to explain as best I can.
The day before yesterday I was working with my GoPiGo reading and processing to the camera and sending signals to the motors to move and everything was just fine. But the next day (yesterday), testing the same code I did it doesn’t work, and not only that, any example program work.
I tried to run the ‘basic_test_all.c’, and trying to move the motors or the sensor it throws this error:
“Error writing to GoPiGo (errno5)”.
I watched the function of ‘gopigo.c’ that throws that error and is: int write_block(char cmd,char v1,char v2,char v3).
I tried to fix the error doing several things like:
Changing the position of the motor wires (white-black-white-black to others positions).
I checked it out all the connections at the GoPiGo and saw that everything is in place.
Reinstall the last firmware version of the GoPiGo.
I also execute the test of the GoPiGo and gave this ‘logs.txt’:
Check space left
/dev/root 29G 6.0G 22G 22% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 87M 460K 86M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 173M 0 173M 0% /run/shm
/dev/mmcblk0p1 56M 20M 37M 36% /boot
Check for dependencies
python 2.7.3-4+deb7u1 install ok installed
python-pip 1.1-3 install ok installed
git 1:1.7.10.4-1+wheezy3+rpi1 install ok installed
libi2c-dev 3.1.1+svn-1 install ok installed
python-serial 2.5-2.1 install ok installed
python-rpi.gpio 0.6.2~wheezy-1 install ok installed
i2c-tools 3.1.1+svn-1 install ok installed
python-smbus 3.1.1+svn-1 install ok installed
arduino 1:1.0.1+dfsg-7 install ok installed
minicom 2.6.1-1 install ok installed
scratch 1.4.20131203-2 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.32
Raspberry Pi Details:
- Device tree is enabled.
- This Raspberry Pi supports user-level GPIO access.
-> ie. export WIRINGPI_GPIOMEM=1
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 005: ID 046d:c534 Logitech, Inc.
|__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/5p, 480M
|__ Port 1: Dev 3, If 0, Class=vend., Driver=smsc95xx, 480M
|__ Port 5: Dev 4, If 0, Class=hub, Driver=hub/4p, 480M
|__ Port 3: Dev 5, If 0, Class=HID, Driver=usbhid, 12M
|__ Port 3: Dev 5, If 1, Class=HID, Driver=usbhid, 12M
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: Device signature = 0x000102
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
Double check chip, or use -F to override this check.
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version and CPU Speed and Voltage
v -1
CPU speed: -1
-1 V
CHECKING ENCODER READINGS
-1 -1
Both motors moving Forward with LED On
after 5 sec -1 -1
Both motors stopped with LED Off
-1 after stop cmd -1 -1
-1 after 2 more sec -1 -1
Both motors moving back with LED On
after 5 sec -1 -1
CHECKING ENCODER TARGETING
Initial encoder read vals: -1 -1
File “/home/pi/Desktop/GoPiGo/Software/Python/tests/enc_tgt_test.py”, line 69, in
enc_stat=read_enc_status()
File “build/bdist.linux-armv6l/egg/gopigo.py”, line 549, in read_enc_status
File “build/bdist.linux-armv6l/egg/gopigo.py”, line 541, in read_status
I don’t know what the mistake might be. I’m thinking that it could be a bad connection betwern the RaspberryPi - Arduino but everything is well connected.
I appreciate your time and your answers.
Best regards, Nacho
