Hi RobertLucian,
During the weekend I ran serval tests with my Grovepi’s (note both have the latest 1.3.0 Firmware).
This is what I did.
I fomated a fresh 8gb sb card and installed Raspbian Stretch with desktop.
expanded the file system, and activated 12c, spi, serial,etc, and rebooted.
I then installed sudo curl -kL dexterindustries.com/update_grovepi | bash, and rebooted.
I connect a grove led to D4 and Grove bmp180 to on of the 12c ports
I ran sudo i2cdetect -y 1
00:          -- 04 -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- 77
All normal
I then ran grove_led_blink.py which worked, followed by sudo i2cdetect -y 1
again.
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Not normal.
I then rebooted and sudo i2cdetect -y 1
I then ran /home/pi/Dexter/GrovePi/Software/Python/grove_barometer_sensors/barometric_sensor_bmp180/grove_i2c_barometic_sensor_example.py
sudo python grove_i2c_barometic_sensor_example.py
Temperature: 17.00 C
Pressure:    1031.42 hPa
Altitude:    -152.23 m
All OK
Followed by grove_led_blink.py, that worked OK.
then sudo i2cdetect -y 1
Again not normal.
I the then ran grove_i2c_barometic_sensor_example.py again, with these results.
Error accessing 0x77: Check your I2C address
Temperature: 12.80 C
Pressure:    127.51 hPa
Altitude:    20114.89 m
As you can see something is wrong, I am not sure what may be wrong, but was again when, update_grovepi is ran it downloads, could some of these have changed.
Note:
As far as I can see Adafruit CircuitPython was not downloaded during the update
I hope this info will help solve the problem.
Sorry for the long email
Many thanks Michael
