root@raspberrypi:/home/pi/Desktop/GoPiGo/Firmware# source firmware_update.sh
ATTENTION! Important!
BEFORE PROGRAMMING THE GOPIGO FIRMWARE, DISCONNECT THE MOTORS.
Please confirm that you’ve disconnected the motors.
Have you disconnected the motors before programming the firmware? (y/n)
y
Updating the GoPiGo firmware
Thu Jan 22 19:03:13 UTC 2015
this check.
avrdude done. Thank you.
this check.
Check for GoPiGo Present:
| IOError
| GoPiGo Not Found |
After that ran your troubleshooting.sh script obtained from github (via some of the other posts on the forum):
root@raspberrypi:/home/pi# source troubleshooting.sh
Welcome to Dexter Industries troubleshooting script
This may take a few minutes, please be patient
Press Enter to start…
Check for dependencies
Checking Serial for BrickPi
Checking Hardware revision
Read pins
Check I2C
Error: Could not open file /dev/i2c-0’ or/dev/i2c/0’: No such file or directory
Check the /dev folder
Check BrickPiStatus
python: can’t open file ‘ser.py’: [Errno 2] No such file or directory
Log File Generated
Contact Email:
chris@tetramatrix.com
Please enter your problem description. Press Enter to end
After trying the firmware update on my GoPiGo, I got an error:
python: can’t open file ‘form_fill.py’: [Errno 2] No such file or directory
Error logs sent successfully
Your Problem ID is 29452 . Please post the Problem ID along with the problem description to the Dexter Industries Forums so that we can get back to you with the solution as soon as possible.
Press Enter to exit
My blacklist for the rasp Pi are un-commented.
Thanks for any help!
Chris
