@cleoqc (along with anyone else who may have a clue)
Issue:
As currently deployed, there are TWO different things that must be done to permanently disable access-point mode in the GoPiGo O/S:
- Navigate to the GoPiGo O/S web page at 10.10.10.10 (or “localhost” if you’re directly connected), click on the WiFi signal icon, and then set a connection to the WiFi network of choice,
And THEN you have to. . .
- Execute
sudo systemctl disable start_as_access_point.service
in a terminal window.
Note that neither one alone is sufficient, you must do BOTH in order to succeed.
Question for Nicole:
I would like to be able to create a script or something that I can execute when I start a new GPGOS image to configure it to the way I want it. That is, I want to connect it to network “X”, disabling access-point mode, edit a few files, and install some programs that I always use, (like gddrescue and gparted, etc.).
Theoretically, (
), I can write a script that will do everything I want, EXCEPT setting up the network mode and credentials the way I want them to be set up.
So, the musical question becomes:
How do I programmatically accomplish what changing the network mode in the web page does? ![]()
