That’s hilarious. It must have been there for something at some point.
I came to the conclusion those lines of code are for setting up the SPI interface, which perhaps are needed if you don’t manually enable SPI in raspi-config (which I always do along with I2C as part of my base OS prep). I only needed to remove the pigpiod dependency for Pi5, but it may be it could have been eliminated long ago. (I cannot test other configs now that Dave has a Pi5 - only one PiOS will work on Pi5.)
This whole process (Bookworm PiOS and now Pi5) has led me to diverge farther and farther from the official ~/Dexter/GoPiGo3/Software. I think the only officially supported OS is the pre-packaged GoPiGo OS image. Probably still the right business decision since new GoPiGo3 users don’t seem to be showing up every Monday and Thursday asking for the latest PiOS, but if they will show up I think they can follow my documentation to get up and running on Pi4 or Pi5.
[Solved] New Scare: Input/output error - (SDCard Extender is Cause)
Have the feeling the sdCard is going bad - getting frequent “Input/output error” that causes terminal to report:
$ ls
-bash: /usr/bin/ls: Input/output error
Every post on the Internet talks about disks going bad, so I’m backing up the suspect card to a new sdCard.
@jimrh how do I force an fsck on the next reboot w/o setting up tune2fs.
good luck - hope that fixes the problem
Had GoPi5Go-Dave do 101 360-degree rotations (Gotta love Python…) and at the end - no cigars:
===== Spin 360.0 WHEEL_DIAMETER:66.05 WHEEL_BASE_WIDTH:105.06 mm at 150 dps ========
Encoder Values: 56644 -56686
Turn Processor Time:3815.9ms Wall Time:3.8s
Encoder Value: 57216 -57258
Delta Value: 572 572
Delta Degrees: 359.6 359.6
Accuracy: 99.9% 99.9%
Spin Rate:94.3 dps Wheel Rate:149.9 dps (includes start/stop effect)
^^^^ Turn 100 ^^^^
Spin 360 Wheel Dia:66.05 Base:105.06 mm? (? for help)
^CExiting...
pi@GoPi5Go:~/GoPi5Go/systests/gpg_config $ ls
Found @jimrh post on this:
Super - created last_fsck.sh:
#!/bin/bash
echo -e "Filesystem: /dev/mmcblk0p2 (/)"
sudo tune2fs -l /dev/mmcblk0p2 | grep "Last checked"
and setup_tune2fs.sh:
#!/bin/bash
echo -e "Last filesystem check:"
echo -e "Configuring to run e2fsk next boot"
echo -e "and every 5 boots"
echo -e "and every 7 days"
echo -e "and remount read-only if errors are found"
echo -e "\n"
sudo tune2fs -c 5 -C 6 -i 7d -e remount-ro /dev/mmcblk0p2
and check_filesystem_for_read_only.sh:
#!/bin/bash
echo -e "Root file system status: (ro: read-only, rw: read-write)"
more /proc/mounts | grep /dev/mmcblk0p2
which reported after the first fsck happened:
pi@GoPi5Go:~/GoPi5Go $ utils/check_filesys_for_read_only.sh
/dev/mmcblk0p2 / ext4 rw,noatime 0 0
Since it didn’t mount as read-only, it “blessed” the image.
Second card - same “eventual” Input/output error after running GoPiGo3 in both C++ and Python. I hate mysteries.
Short answer:
No.
Longer answer:
Hell no!!
Especially with a system where strange things can, and do, happen an aggressive fsck schedule is extremely important.
The best way to do that is by setting the filesystem’s parameters so that it forces a regular and frequent fsck using tune2fs.
I set Charlie, (and every other Linux system I have) to a five-day, five mount, forced fsck at boot time.
- It fsck’s every 6th mount.
- It fsck’s after five days if it hasn’t been caught by the mount-count based forced fsck.
Additionally, when I set these parameters in tune2fs, I deliberately set the mount-count to “6”, which forces a fsck on the very next reboot.
One last thing: I set the “on error” behavior to “remount read-only” to prevent further damage.
tune2fs -c 5 -C 6 -i 5 -e "remount-ro" /dev/sda1 (or whatever your device is.)
-c 5Set it to check after every 5th mount if it hasn’t been caught by something else1.-C 6Set the current mount count to “6” so it immediately forces a fsck when rebooted.-i 5Set the interval based checking to every five days if it hasn’t been caught by something else1.-e "remount-ro"If something is found, immediately forces the filesystem to remount as a read-only filesystem.
Note this only works if you regularly reboot. If your robot stays on-line continuously, it will never “catch”.
You set this for each partition individually if there are more than one ext-formatted partitions.
- “Catch/caught”:
Anything that compels an e2fsck resets the interval and mount-count dependent checking as it is “[condition] since last fsck”.
If you are going to perform a manual fsck, also pass the “-D” parameter as it allows e2fsck to optimize the directory tree structure to make it more efficient. Note that it doesn’t change the actual hierarchical structure, (the order of the directories doesn’t change), but optimizes the physical structure within the filesystem to make sure it’s organized efficiently and doesn’t use more i-nodes than necessary. Sort of like defragging, but different.
pi@GoPi5Go:~/GoPi5Go $ df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 1896432 0 1896432 0% /dev
tmpfs 414240 5856 408384 2% /run
/dev/mmcblk0p2 30085184 6841856 21695016 24% /
tmpfs 2071152 32 2071120 1% /dev/shm
tmpfs 5120 64 5056 2% /run/lock
/dev/mmcblk0p1 522230 76542 445688 15% /boot/firmware
tmpfs 414224 128 414096 1% /run/user/1000
I set it up for /dev/mmcblk0p2 but that misses the /boot/firmware partition, no?
This is what it says when I try for the whole parent device /dev/mmcblk0:
pi@GoPi5Go:~/GoPi5Go $ sudo tune2fs -c 5 -C 6 -i 7d -e remount-ro /dev/mmcblk0
tune2fs 1.47.0 (5-Feb-2023)
tune2fs: Bad magic number in super-block while trying to open /dev/mmcblk0
Found a dos partition table in /dev/mmcblk0
pi@GoPi5Go:~/GoPi5Go $ sudo tune2fs -l /dev/mmcblk0p1
tune2fs: Bad magic number in super-block while trying to open /dev/mmcblk0p1
/dev/mmcblk0p1 contains a vfat file system labelled 'bootfs'
Rule 1:
Tune2fs is used for a partition1, (i.e. /dev/sda1, /dev/mmcblk0p2, etc.), not an entire block device, (i.e. /dev/sda, /dev/mmcblk0, etc.).
Rule 2:
Tune2fs is only valid with ext partitions. ext2, ext3 and ext4.
That’s correct. /boot isn’t really a part of root’s ext4 filesystem, being mounted on top of the /boot directory there.
e2fsck only works on the exe2/3/4 partition itself, skipping any overlay mounts as it functions at the partition filesystem level.
tune2fs actually does nothing to the partition per-se as it simply sets partition metadata/flags that control the way the partition operates with respect to its filesystem. For example, “has-journal” is a filesystem attribute. Likewise, so is the current mount count, the maximum mount count, the filesystem’s UUID, label, etc.
If you look up the man-page for ‘mkfs’ will be useful as you can set flags/properties at format time. These properties can also be passed via a manual mount or within the mount string in fstab.
Especially interesting is the “discard” option which enables “discard”/TRIM for solid-state media. (It is disabled by default.) Virtually all SSD’s, both internal and external, support it and some of the later, brand-named, SD cards also support it, or ignore it if specified.
- It is possible to format an entire block device, (there are some early systems that used a partitionless hard drive format, such as early Winchester-type MFM/RLL hard drives), but it’s very unusual and is not normally done in a modern operating system.
- I actually did that once while trying to create one of my very first RAID systems on a 'nix box, but it was strange and did weird things - I ended up moving the data off of it and reformatting it in a more conventional way.
Credit where credit is due:
Though I might be good at this kind of stuff, you absolutely beat the pants off of me when it comes to down-and-dirty coding!
At risk of mangling a great line from Fiddler on the Roof, you code things that would cross a rabbi’s eyes! ![]()
And GoPi5Go-Dave really needs a hardware doctor. I do not believe my GoPiGo code can make the sd card suddenly non-readable to an “ls” command, (and prevent further remote connections).
The GoPiGo3 programs continue driving Dave, and reading the GoPiGo3 battery voltage as long as the program operates on RAM, but die if they try to write to the SDCard.
I have a status program running that says no temperature or voltage throttling is or has occurred, (and that low voltage detection is really sensitive and trustworthy, at least it always has been on Pi3 and Pi4).
Since the only way to recover is to reboot, I don’t know how to see a log entry of why the SDCard became inaccessible.
Stupid questions:
- Did you try a hard reboot? (i.e. full shutdown, remove power, wait 30 seconds, and reboot.)
- Did you try removing the SD card and inserting into a different Linux system? You can fsck it there, even if it remounts r/o, because fsck only works on unmounted partitions.
No other way to recover, since any command I enter, such as “shutdown -h now” tries to find the shutdown program on the card which is not readable. I have to jerk the power, which luckily is no longer risky because the SDCard is not accessible at that point.
The tune2fs -c 5 -C 6 caused the check before the partition was mounted at boot time, as I understand it, but no, I have not tried from another Linux system.
Also run a sudo tune2fs -l /dev/mmcblk0p2 (note that “-l” is a lower-case “L”)
This will list all the current attributes of the partition. Post it here.
You can also put a generic file system into Dave temporarily, then insert the card using an SD card USB adapter and fsck it there.
Note that there are two utilities that should be installed on every linux system, including the robots:
- gparted.
- ddrescue
sudo apt-get install gparted gddrescue will get them for you. This should be a standard part of your initial setup routine.
pi@GoPi5Go:~/GoPi5Go $ ls
config Graphics LICENSE logs plib README.md saved status.sh systests utils
pi@GoPi5Go:~/GoPi5Go $ sudo tune2fs -l /dev/mmcblk0p2
Filesystem volume name: rootfs
Last mounted on: /
Filesystem UUID: fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9
Filesystem magic number: 0xEF53
Filesystem revision #: 1 (dynamic)
Filesystem features: has_journal ext_attr resize_inode dir_index filetype needs_recovery extent flex_bg sparse_super large_file dir_nlink extra_isize metadata_csum
Filesystem flags: unsigned_directory_hash
Default mount options: user_xattr acl
Filesystem state: clean
Errors behavior: Remount read-only
Filesystem OS type: Linux
Inode count: 1886976
Block count: 7659648
Reserved block count: 382982
Free blocks: 5810832
Free inodes: 1709668
First block: 0
Block size: 4096
Fragment size: 4096
Reserved GDT blocks: 321
Blocks per group: 32768
Fragments per group: 32768
Inodes per group: 8064
Inode blocks per group: 504
Flex block group size: 16
Filesystem created: Fri Mar 15 11:11:08 2024
Last mount time: Thu Mar 28 07:27:57 2024
Last write time: Thu Mar 28 09:28:10 2024
Mount count: 4
Maximum mount count: 5
Last checked: Wed Mar 27 12:49:21 2024
Check interval: 604800 (1 week)
Next check after: Wed Apr 3 12:49:21 2024
Lifetime writes: 63 GB
Reserved blocks uid: 0 (user root)
Reserved blocks gid: 0 (group root)
First inode: 11
Inode size: 256
Required extra isize: 32
Desired extra isize: 32
Journal inode: 8
Default directory hash: half_md4
Directory Hash Seed: 754db390-ca56-4b3a-b935-14c23d4e6fdb
Journal backup: inode blocks
Checksum type: crc32c
Checksum: 0
That looks OK, now you need to move it to another system, (or Dave with a copy of GoPiGoO/S), and run a sudo fsck -f -v -D /dev/mmcblk0p2
You might want to run it the first time with a “-n” just to see what it would do. Ultimately you’re going to run it as listed to actually fix it.
Tested with journalctf -kf running and got a hit after only 6 rotations of Dave:
********* GoPi5Go-Dave STATUS *****
2024-03-28 09:53:36 up 2:25, 3 users, load average: 0.24, 0.05, 0.02
Current Battery 12.3v (Reading 11.55v)
5v Supply: 4.98
Processor Temp: 46.6'C
Clock Frequency: 1.50 GHz
throttled=0x0
File "/home/pi/GoPi5Go/plib/status.py", line 131, in <module>
File "/home/pi/GoPi5Go/plib/status.py", line 119, in main
File "/home/pi/GoPi5Go/plib/status.py", line 79, in printStatus
File "/home/pi/GoPi5Go/plib/status.py", line 74, in getUptime
File "<frozen os>", line 987, in popen
File "/usr/lib/python3.11/subprocess.py", line 1024, in __init__
File "/usr/lib/python3.11/subprocess.py", line 1901, in _execute_child
OSError: [Errno 5] Input/output error: '/bin/sh'
./status.sh: error reading input file: Input/output error
pi@GoPi5Go:~/GoPi5Go $ journalctl -kf
Mar 28 07:27:59 GoPi5Go kernel: macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
Mar 28 07:27:59 GoPi5Go kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Mar 28 07:27:59 GoPi5Go kernel: Bluetooth: BNEP filters: protocol multicast
Mar 28 07:27:59 GoPi5Go kernel: Bluetooth: BNEP socket layer initialized
Mar 28 07:27:59 GoPi5Go kernel: Bluetooth: MGMT ver 1.22
Mar 28 07:27:59 GoPi5Go kernel: NET: Registered PF_ALG protocol family
Mar 28 07:27:59 GoPi5Go kernel: brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
Mar 28 07:28:13 GoPi5Go kernel: Bluetooth: RFCOMM TTY layer initialized
Mar 28 07:28:13 GoPi5Go kernel: Bluetooth: RFCOMM socket layer initialized
Mar 28 07:28:13 GoPi5Go kernel: Bluetooth: RFCOMM ver 1.11
Mar 28 09:53:35 GoPi5Go kernel: mmc0: Card stuck being busy! __mmc_poll_for_busy
My rotation program continues to operate just fine because it does not invoke anything that needs to access the sdcard.
You need to know the status of the SD card and/or filesystem. There is a distinct possibility that the SD card has begun to go all pear-shaped.
Have you tried removing it and cleaning all the contacts with a clean eraser? Do that and then fsck it.
Interesting - As part of the recovery from that “mmc0: Card stuck being busy!” (exclamation point theirs…), I plugged the sdcard directly into the Pi5, rather than the sdcard extender.
Also since the mount count was at 4, restarted twice to trigger the fsck:
pi@GoPi5Go:~/GoPi5Go $ utils/last_fsck.sh
Last checked: Thu Mar 28 10:08:53 2024
Last mounted on: /
Free blocks: 5808805
Free inodes: 1709688
First block: 0
Block size: 4096
Fragment size: 4096
Last mount time: Thu Mar 28 10:08:56 2024
Last write time: Thu Mar 28 10:08:53 2024
Mount count: 1
Next check after: Thu Apr 4 10:08:53 2024
First inode: 11
Inode size: 256
Journal inode: 8
Checksum: 0x76313ff1
Going to try test again with SDcard in the Pi5 rather than extender… 20 rotations so far no busy notice… maybe… (30 spin360 completed and Dave is only 2 to 3 degrees off original heading… not too shabby)
