We are trying to connect a camera to our GoPiGo 3, using a Raspberry Pi 4 Model B 8GB RAM and when we connect a USB Flash Drive, but our computer does not seem to recognise it.
Hey, thanks for the replies. I have successfully connected the USB to the GoPiGo, its being detected without any issues. I am running the GoPiGo on the latest OS.
I am still having issues however with the Camera module not being detected. I have plugged it in correctly according to the tutorials. The rapiconfig is setup to enable the camera interface so it should be working. I am not sure what else I can troubleshoot and checkk for faults.
I have attached a picture of the connectivity, let me know if anything is plugged in correctly.
Make sure the contacts on the cable are facing the contacts on the connector.
If I remember rightly, the blue part of the cable should face the movable “clip” part of the connector.
Additionally, make sure the cables are fully inserted.
One last thing:
Make sure the camera’s connector is firmly plugged into the camera board. You can carefully unplug it by pulling it straight up away from the board. It should require a bit of effort to remove it, and it should re-install with a noticable “click”.
If this doesn’t resolve your problem, you can try the camera in a different Pi board. Camera modules do go bad and Pi boards fail too.
Also try a different camera ribbon cable. 99% of the camera problems I have experienced have been traced back to a defective ribbon cable.
