Right now v1.3 is in beta so you would have to install it directly from it’s page. If it works well for everyone, we would make it default in a few weeks.
Hey Muskoka, are you pasting the line in, or typing it out? If you’re pasting it, can you try typing it? Sometimes new line errors get added, especially with windows.
If you’re typing it, can you send us a quick screenshot, or tell us if there are any more errors around the command?
Thanks Karan, the motors were disconnected. I’m going to do a “fresh” install with your image from Feb 17(downloaded), update to fw 1.3, and see what happens.
Started from scratch, re-installed everything, updated everything, installed firmware 1.3, and everything is working as it should. Led’s are controllable in Scratch, didn’t need any trim on the drive, it’s moving straight without any trim, at least up to 15’ so far.
Thanks for the updates Karan / John, working great.
I should add, I’m also getting the error posted above by nkilbourn. If you give the tr cmd, the script quits right back to the command line, with the error he posted.
On sudo git pull I got the message :
updating b5edb37…d1e2609
error : Your local changes to the following files would be overwritten by merge :
Software/Python/basic_test_all.py
Software/Scratch/GoPiGoScratch.py
Please, commit your changes or stash them before yoy can merge.
Aborting
