I got a gopigo3 3 days back! I am trying to work it out! I am using normal Raspbian OS.
I installed GoPiGo’s libraries by following command-
sudo curl -kL dexterindustries.com/update_gopigo3 | bash
then I created a simple python sketch to move bot forward and backward!
But it is giving fatal error, saying that firmware version is not 1.0.x, it is 0.3.4
I have updated the firmware but nothing happens?? HELP!!
Hi @sakshambhutani2001,
For installing everything, it should have been something like:
curl -kL dexterindustries.com/update_gopigo3 | sudo bash
Using it without sudo will ignore some dependencies, so I suggest you run it this way.
Now, for updating the firmware, you have to run the flasher manually:
bash GoPiGo3/Firmware/gopigo3_flash_firmware.sh
This will get it installed and you should have a functional robot.
Your file path for the firmware script was a bit off… but so far so good!
I am having similar issues.
Thanks for the lines of code!
Path was (is)
/Dexter/GoPiGo3/Firmware/ then the script.
