GoPiGo install.sh breaks apt-get on debian jessie
I ran into problems while installing ROS Indigo on the GoPiGo.
these are the steps I took and the way I solved it.
things stopped working when doing the ‘sudo apt-get update’
apparently the GoPiGo install.sh copies a python script named ‘gpg’ to /usr/bin
that’s a problem because SecureApt uses /usr/bin/gpg assuming it’s the GNU Privacy Guard
overwriting /usr/bin/gpg with the original file (from another Pi) fixed the problem.
I think the GoPiGo install.sh script should not copy to /usr/bin.
Hey fandarel,
Thanks a lot for letting us know about the problem with gpg being copied to /usr/bin. We had done that earlier to give users a way to check the status of the GoPiGo directly from a command on the terminal. We have not been using it a lot and will remove that in the next update.
This is still an issue in the current release it seems.
apt-key and pgp --import are not working when trying to import a key
Im trying to install uv4l and update, following the install guide at:
http://www.linux-projects.org/uv4l/installation/
Is there any work-a-round available?
Hey facilis, not sure, are you working with Raspbian for RObots? The original poster was not; can you confirm?
Hi John,
Yes i am working with Raspbian for Robots version 2016.06.15 i think. When i cat /usr/bin/gpg i get
#!/bin/bash
python /home/pi/Desktop/GoPiGo/Software/Python/other_scripts/gopigo_status.py
That got fixed approximately two weeks ago. The Dexter file called gpg has been renamed to gopigo and no longer interferes with Gnu Privacy Guard, but it’s impossible to remove /usr/bin/gpg as it could be the right thing.
Feel free to copy over the proper gpg from a regular Raspbian.
Future Raspbian for Robots will not have this issue.
Will give that a go, thank you
