Sorry for the delay. See the log at the bottom of this post.
Regarding the batteries, they were all brand new fresh batteries when we put them in. I just metered them, after all the testing we’ve been doing, and we’re just now down to 10v (out of the 12v possible). I’m not feeling it’s related to the batteries.
As I mentioned earlier, the issue is not consistent. Without changing anything, sometimes the wheels move perfectly at the same speed, and then others not. In a situation where one wheel is not consistently moving at a different speed, the trim function does not seem to be the correct route. Would you agree? Seems like if I speed it up, then it will go too fast half the time.
I must say, at this point I am quite frustrated. After dropping $400 for a GoBox subscription for my son, the delivered product has so far given me buyers remorse. Unfortunately, first, he was quite disappointed when the unit initially arrived, and he put it together, all he could do with it was wait another month for an actual mission to do. I had presumed his first mission would have been included. Guess not. So, after waiting for a month for something to arrive for him to actually do with the GoPiGo, we were disappointed that the first mission didn’t even include a sensor. Instead it was simply to drive the GoPiGo around, which he already could do (why did we have to wait a month for this “mission”??). This was the mission? Ok, so let’s drive it around. Then we were frustrated by the fact that it does not even drive in a straight line reliably enough to complete that simplistic goal.
I’m not sure if we’ve got a bum unit, or what. All I know is, at this point, my son’s pretty much done with the GoPiGo, and I’m getting really close too. As a programmer myself, I understand that the journey is often the lesson. However, if we have gear that’s malfunctioning, we’re essentially setup to fail. I suspect that wasn’t the intention.
-= Brandon.
Here is the log…
Check space left
/dev/root 3.5G 2.9G 427M 88% /
devtmpfs 182M 0 182M 0% /dev
tmpfs 38M 424K 37M 2% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 75M 0 75M 0% /run/shm
/dev/mmcblk0p1 56M 20M 36M 36% /boot
Check for dependencies
python 2.7.3-4+deb7u1 install ok installed
python-pip 1.1-3 install ok installed
git 1:1.7.10.4-1+wheezy3+rpi1 install ok installed
libi2c-dev 3.1.1+svn-1 install ok installed
python-serial 2.5-2.1 install ok installed
python-rpi.gpio 0.6.2~wheezy-1 install ok installed
i2c-tools 3.1.1+svn-1 install ok installed
python-smbus 3.1.1+svn-1 install ok installed
arduino 1:1.0.1+dfsg-7 install ok installed
minicom 2.6.1-1 install ok installed
scratch 1.4.20131203-2 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.32
Raspberry Pi Details:
Type: Model B+, Revision: 02, Memory: 512MB, Maker: Sony
- Device tree is enabled.
- This Raspberry Pi supports user-level GPIO access.
-> ie. export WIRINGPI_GPIOMEM=1
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
|__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/5p, 480M
|__ Port 1: Dev 3, If 0, Class=vend., Driver=smsc95xx, 480M
|__ Port 2: Dev 4, If 0, Class=vend., Driver=rtl8192cu, 480M
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
Reading | ################################################## | 100% 0.02s
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0’ or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
00: – -- – -- – 08 – -- – -- – -- –
70: – -- – -- – -- – --
Checking for firmware version and CPU Speed and Voltage
v 1.6
CPU speed: 2
8.04 V
CHECKING ENCODER READINGS
0 0
Both motors moving Forward with LED On
after 5 sec 116 127
Both motors stopped with LED Off
None after stop cmd 121 131
None after 2 more sec 122 132
Both motors moving back with LED On
after 5 sec 237 258
None after stop cmd 241 262
None after 2 more sec 243 263
CHECKING ENCODER TARGETING
Initial encoder read vals: 0 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 0
Final encoder read vals: 72 79
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 0
Final encoder read vals: 72 78
Initial encoder read vals: 0 2
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 0
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 0
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 0
