Thank you for your help. Here’s what I have as the output of the three commands:
pi@raspberrypi ~ $ sudo i2cdetect -y 1
70: – -- – -- – -- – --
pi@raspberrypi ~/Desktop/GoPiGo/Software/Python $ sudo ./basic_test_all.py
Cmd: v
-1 V
Cmd: f
v -1
pi@raspberrypi ~/Desktop $ sudo ./firmware_update.sh
ATTENTION! Important!
BEFORE PROGRAMMING THE GOPIGO FIRMWARE, DISCONNECT THE MOTORS.
Please confirm that you’ve disconnected the motors.
Have you disconnected the motors before programming the firmware? (y/n)
y
Updating the GoPiGo firmware
Thu Sep 17 17:51:17 EDT 2015
Reading | ################################################## | 100% 0.01s
avrdude: reading input file "0x7F"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0x7F:
avrdude: load data lfuse data from input file 0x7F:
avrdude: input file 0x7F contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: verifying …
avrdude: 1 bytes of lfuse verified
avrdude: safemode: Fuses OK
avrdude done. Thank you.
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "fw_ver_13.cpp.hex"
avrdude: input file fw_ver_13.cpp.hex auto detected as Intel Hex
avrdude: writing flash (10748 bytes):
Writing | ################################################## | 100% 12.20s
avrdude: 10748 bytes of flash written
avrdude: verifying flash memory against fw_ver_13.cpp.hex:
avrdude: load data flash data from input file fw_ver_13.cpp.hex:
avrdude: input file fw_ver_13.cpp.hex contains 10748 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 10.21s
avrdude: 10748 bytes of flash verified
Unfortunately, there is no response still. The i2cdetect shows no change.
Anything else I can try?
Thanks.
Richard Clement
