GoPiGo O/S and the new V3 Camera
First formal start of Charlene and I made two rapid discoveries:
  1. One of the blinkers doesn’t work.  This will require additional troubleshooting but is probably fixable.
  2. The new Raspberry Pi Camera V3 does not work with the latest GoPiGo O/S.
I am not sure but I am suspecting that there was a change in the camera libraries, (as I remember there was a change in the camera libraries), and the new camera requires the new library.
The issue this creates is that if you have GoPiGo O/S installed and try to use the “Drive” functionality from the on-board web page, you get enough space for the picture, but no video.  Not even a frame.
I am going to mess with it and document results here.
Update:
With respect to the current release of GoPiGo O/S, (3.0.3):
No vodka and caviar for you, comrade!
From the Pycamera GitHub repository:
From another site:
It appears that Picamera2 is a hard requirement for the V3 camera and to get Picamera2, you gotta have Bullseye or later.
There doesn’t even seem to be a way to side-load it.
Conclusion:
There’s going to need to be an update to GoPiGo O/S using a later version of Raspberry Pi O/S.
Has anyone tried installing the GoPiGo libraries on Raspberry Pi O/S “Bookworm”?
