GoPiGo with RPI zero w requires a wifi dongle?
Hi all,
I am interested in using a Raspberry Pi Zero W on a GoPiGo robot.
I have seen it is possible to use a Raspberry Pi Zero with a GoPiGo:
https://www.dexterindustries.com/projects/gopigo-raspberry-pi-zero/
however this requires a wifi dongle.
My first question is: since I have a Raspberry Pi zero W do I still need that ?
I installed CINCH on an SD card and turned on the Raspberry Py but the dex network does not appear so maybe I do need the dongle?
Second question is, if I do need the wifi dongle, does it come with the GoPiGo base kit ?
Thank you very much,
Alex.
Hi @alex.farinelli,
The Raspberry Pi Zero W already has a built-in WiFi module, so you are all set. No need to buy a WiFi dongle. With that being said, this means the GoPiGo base kit does not come with a WiFi dongle.
Regarding Cinch, can you describe us the steps you have followed?
Also, @cleoqc, what do you think?
Hi @RobertLucian,
thanks for your answer!
I downloaded Cinch from here:
https://sourceforge.net/projects/dexterindustriesraspbianflavor/files/Cinch/
and followed the instruction provided here:
https://www.dexterindustries.com/howto/install-raspbian-for-robots-image-on-an-sd-card/
to build a microSD card.
Everything seems to work fine with flashing the card. I then inserted the card into my Raspberry Pi and power it throw a usb cable.
The card turns on and after some booting time (green light flashing) I got a steady green light.
I then looked for a network named dex with my laptop but could not find it.
Any idea on what should I do to connect via the built-in WIFI module to the Raspberry Pi Zero W ?
Hi @alex.farinelli,
That’s peculiar. Do you happen to have by chance a regular Raspberry Pi 3 to test with?
We might try running that on a Raspberry Pi 3 instead and if it still doesn’t work, then there’s something bad with Cinch itself.
Hi @RobertLucian,
unfortunately I do not have a Raspberry Pi 3 immediately available, but I might be able to ask around for one and see if I can do a quick test. To make sure I understand you propose to insert the same SD card on a Raspberry Pi 3 and check if the network dex appears ?
While I look around for the Raspberry Pi 3 if you can think of any other test to do please let me know.
Thanks.
Hi @alex.farinelli,
That’s correct, you’re right.
And if anything shows up on my side, I’ll let you know.
