GoPiGo3 Doc Issue - EasyDistanceSensor
Section 5.3. API - Library - Sensors does not have an EasyDistanceSensor section
Section 5.1.3.1 Classes Short-List graphic does not contain the EasyDistanceSensor
Section 5.1.3.2.1.3. Sensor/Actuator does not list the easysensor.distance_sensor APIs (that are missing from Section 5.3)
Hello @cyclicalobsessive
I understand this is confusing but the distance sensor is not a part of the GoPiGo3 documentation because it can be used with all our robots.
You will find its documentation here:
https://di-sensors.readthedocs.io/en/master/api-basic.html#easydistancesensor
We will consider linking to it from the GoPiGo3 docs, if technically feasible.
Thanks for pointing it out!
Hi Cleo,
Oh, no problem. Since the EasyGoPiGo3.init_distance_sensor() method is included in the GoPiGo3 doc, and API methods are included for all the other sensors that have an EasyGoPiGo3.init_xxx method, the distinction was not evident.
I see that the other DI Sensors do not have init methods listed in the EasyGoPiGo3 doc, so perhaps the easiest is to remove the init_distance_sensor() API, and make mention of more sensors with a link to the DI-Sensors docs.
The DI docs are already very impressive for both content and organization. The DI product line has grown quickly and matured responsively to your users. Thanks.
