@cleoqc - please read and comment.
The problem is that the easygps library is broken as it is missing its fundamental “read” method.
Viz.:
This is the equivelent Python code generated by Bloxter when it attempts to read the GPS sensor.
import easygopigo3 as easy
import time
import easygps
gpg = easy.EasyGoPiGo3()
gps_sensor = easygps.GPS()
gps_sensor.read() # take an initial reading
# start
print(gps_sensor.get_latitude())
time.sleep(0.2)
time.sleep (1)
print(gps_sensor.get_longitude())
time.sleep(0.2)
time.sleep (1)
time.sleep(0.05) # slowdown
This is the easygpg.py library file:
(Note the absence of a “read” method.)
import serial, time, sys
import re
from multiprocessing import Process, Queue
en_debug = False
def debug(in_str):
if en_debug:
print(in_str)
patterns=["\$GPGGA",
"[0-9]+\.[0-9]+", # timestamp hhmmss.ss
"[0-9]+.[0-9]+", # latitude of position
"[NS]", # North or South
"[0-9]+.[0-9]+", # longitude of position
"[EW]", # East or West
"[012]", # GPS Quality Indicator
"[0-9]+", # Number of satellites
"[0-9]+.[0-9]+", # horizontal dilution of precision x.x
"[0-9]+\.[0-9]+" # altitude x.x
class GPS():
def __init__(self,port='/dev/ttyAMA0',baud=9600,timeout=0, delay_to_die=10):
self.ser = serial.Serial(port, baud, timeout=timeout)
self.ser.flush()
self.raw_line = ""
self.gga = []
self.validation =[] # contains compiled regex
self.time_to_die = time.time()
self.delay_to_die = delay_to_die # how long do we keep a value before requesting another read
self.threaded_access = None
self.queue = None
# compile regex once to use later
for i in range(len(patterns)-1):
self.validation.append(re.compile(patterns[i]))
self.clean_data()
def clean_data(self):
clean_data:
ensures that all relevant GPS data is set to either empty string
or -1.0, or -1, depending on appropriate type
This occurs right after initialisation or
after 50 attemps to reach GPS
self.timestamp = ""
self.lat = -1.0 # degrees minutes and decimals of minute
self.NS = ""
self.lon = -1.0
self.EW = ""
self.quality = -1
self.satellites = -1
self.altitude = -1.0
self.latitude = -1.0 #degrees and decimals
self.longitude = -1.0
self.fancylat = "" #
def _threaded_read(self, q):
Start a thread to query the GPS as this can loop up to 50 times when the GPS is unable
to get a proper reading. As soon as a reading is valid, exit background thread.
An exit code of 0 means we have a valid reading.
An exit code of 1 means we cannot get a reading after 50 reads, or an empty line
debug ("starting thread")
for i in range(50):
time.sleep(0.5)
self.raw_line = self.ser.readline()
# an empty line means the GPS isnt ready to send data
if (self.raw_line == b""):
exit(1)
try:
self.line = self.raw_line.decode('utf-8')
self.line = self.line.strip()
except: #leftover from Python2
debug(f"DATA #{i}: {self.line}")
if self.validate(self.line):
q.put (self.line)
self.ser.reset_input_buffer()
exit(0)
# else:
# print ("invalid line")
debug ("Giving up")
exit (1)
def control_panel_read(self):
Starts a non-blocking background thread that attempts 50 times at most to get valid data from GPS
If a thread is found to be already running, then just exit
It's expected that control_panel_read() is being called repeatitively
and that a reading will caught on the following call.
If valid data is not found, then clean up data in GPS instance
return_value = 0
if self.queue == None:
self.queue = Queue()
if self.threaded_access == None:
# start the background process
debug ("starting first process")
self.threaded_access = Process(target=self._threaded_read, args=(self.queue,))
self.threaded_access.start()
if self.threaded_access.is_alive() is False:
# query background process
if self.threaded_access.exitcode == 0:
if self.queue.empty() is False:
gga = self.queue.get()
self.parse_gga(gga)
debug ("FOUND: ")
debug (self.gga)
return 0
else:
# we got an exit code indicating failure
debug("cleaning up")
self.clean_data()
return_value = 1
# start the next background process
debug("starting next process")
else:
# debug("nothing to do but wait")
return_value = 2
return return_value
def validate(self, in_line):
Runs regex validation on a GPGAA sentence.
Returns False if the sentence is mangled
Return True if everything is all right and sets internal
class members.
if in_line == "":
return False
if in_line[:6] != "$GPGGA":
return False
self.gga = in_line.split(",")
# debug("in validate():")
# debug (self.gga)
#Sometimes multiple GPS data packets come into the stream. Take the data only after the last '$GPGGA' is seen
try:
ind=self.gga.index('$GPGGA',5,len(self.gga))
self.gga=self.gga[ind:]
except ValueError:
pass
if len(self.gga) != 15:
debug ("Failed: wrong number of parameters ")
debug (self.gga)
return False
for i in range(len(self.validation)-1):
if len(self.gga[i]) == 0:
debug (f"Failed: empty string {i}")
self.ser.flush()
return False
test = self.validation[i].match(self.gga[i])
if test == None:
debug (f"Failed: wrong format on parameter {i}: {self.gga[i]}")
return False
else:
# debug("Passed %d"%i)
pass
self.parse_gga(self.gga)
return True
def parse_gga(self, in_gga):
# in_gga may be a str or a list. We need it in a list
try:
self.gga = in_gga.split(",")
except:
pass
try:
self.timestamp = self.gga[1]
self.lat = float(self.gga[2])
self.NS = self.gga[3]
self.lon = float(self.gga[4])
self.EW = self.gga[5]
self.quality = int(self.gga[6])
self.satellites = int(self.gga[7])
self.altitude = float(self.gga[9])
self.latitude = self.lat // 100 + self.lat % 100 / 60
if self.NS == "S":
self.latitude = - self.latitude
self.longitude = self.lon // 100 + self.lon % 100 / 60
if self.EW == "W":
self.longitude = -self.longitude
except ValueError as e:
debug( "FAILED: invalid value")
debug( e)
def get_latitude(self):
if time.time() - self.time_to_die > self.delay_to_die:
self.read()
return round(self.latitude,6)
def get_longitude(self):
self.read()
return round(self.longitude,6)
def convert(self, coord_in):
degrees = int(coord_in)
# print(f"Degrees: {degrees}")
minutes = int((coord_in - degrees) * 60 )
# print(f"Minutes: {minutes}")
seconds = round((coord_in - degrees - (minutes/60)) * 3600,2)
# print(f"Seconds: {seconds}")
return f"{degrees}°{minutes}'{seconds:{2}.2f}"
def get_latitude_str(self):
self.read()
return self.convert(abs(self.latitude))+self.NS
def get_longitude_str(self):
self.read()
return self.convert(abs(self.longitude))+self.EW
def get_utc0_time(self):
self.read()
return f"{self.timestamp[:2]}:{self.timestamp[2:4]}:{self.timestamp[4:6]}"
def get_nb_satellites(self):
self.read()
return self.satellites
if __name__ =="__main__":
print("STARTING GPS")
gps = GPS()
time.sleep(5)
in_data = gps.read()
# print (f"read: {in_data}")
print(f"lat: {gps.lat}, N/S: {gps.NS}, long: {gps.lon}, E/W: {gps.EW}, nb satellites: {gps.satellites}, google: {gps.convert(abs(gps.latitude))+gps.EW}, {gps.convert(abs(gps.longitude))+gps.NS} ")
assert(gps.convert(45.504103)=="45°30'14.77")
assert(gps.convert(73.806683)=="73°48'24.06")
This is the grovegps library file gps_reading.py
Note that this works, (but doesn’t parse properly), and has a “read” method.
#!/usr/bin/env python
# This example demonstrates how to use the Grove GPS sensor with the GoPiGo3.
# Connect the GPS sensor to the SERIAL port on the GoPiGo3. This port
# is on the right hand side of the GoPiGo3.
from __future__ import print_function
import re
en_debug = False
def debug(in_str):
if en_debug:
print(in_str)
patterns=["$GPGGA",
"/[0-9]{6}\.[0-9]{2}/", # timestamp hhmmss.ss
"/[0-9]{4}.[0-9]{2,/}", # latitude of position
"/[NS]", # North or South
"/[0-9]{4}.[0-9]{2}", # longitude of position
"/[EW]", # East or West
"/[012]", # GPS Quality Indicator
"/[0-9]+", # Number of satellites
"/./", # horizontal dilution of precision x.x
"/[0-9]+\.[0-9]*/" # altitude x.x
class GROVEGPS():
def __init__(self,port='/dev/serial0',baud=9600,timeout=0):
self.ser = serial.Serial(port,baud,timeout=timeout)
self.ser.flush()
self.raw_line = ""
self.gga = []
self.clean_data()
# self.get_date() # attempt to gete date from GPS.
clean_data:
self.timestamp = ""
self.NS = ""
self.lon = -1.0
self.EW = ""
self.quality = -1
def get_date(self):
attempt to get date from GPS data. So far no luck. GPS does
not seem to send date sentence at all
function is unfinished
valid = False
for i in range(50):
time.sleep(0.5)
print (i)
self.raw_line = self.ser.readline().strip()
if self.raw_line[:6] == "GPZDA": # found date line!
print ("")
print (self.raw_line)
def read(self):
Attempts 50 times at most to get valid data from GPS
Returns as soon as valid data is found
valid = False
for i in range(50):
time.sleep(0.5)
print(self.raw_line)
if self.validate(self.raw_line):
valid = True
break;
if valid:
return self.gga
else:
print("Invalid/no data received")
self.clean_data()
return []
def validate(self,in_line):
class members.
if in_line == "":
return False
return False
debug (self.gga)
try:
except ValueError:
pass
debug (self.gga)
return False
debug ("Failed: empty string %d"%i)
return False
if test == False:
debug ("Failed: wrong format on parameter %d"%i)
return False
else:
try:
if self.NS == "S":
if self.EW == "W":
except ValueError:
return True
gps = GROVEGPS()
print("Reading GPS sensor for location . . . ")
print("If you are not seeing coordinates appear, your sensor needs to be")
print("outside to detect GPS satellites.")
time.sleep(2)
if in_data != []:
# Print out the GPS coordinates in Google Coodinates.
# You should be able to paste these into maps.google.com
# and see your location.
print ("Lat: {} North/South: {} Long: {} East/West: {}".format(gps.lat, gps.NS, gps.lon,gps.EW))
print ("Expanded Lat: {} Expanded Long: {}".format(gps.latitude, gps.longitude))
What I suspect happened is that, originally, Bloxter was intended to run as a part of DexterOS and be compatible with the GrovePi - and that you would use GrovePi methods on an earlier GoPiGo.
The easygps library appears to be a half-finished attempt to port the Grove library over to the GoPiGo. I am going to try renaming methods in the Grove version to conform to what the GoPiGo wants and see what happens.
Additional notes:
There are also easypicamera and easyusb libraries in the egg file for the gps. IMHO, I think the easygps should be part of easysensors.
