Guys,
I’ve purchased a Grove - 2-Coil Latching Relay.
I’ve found that you have a Relay listed on your http://www.dexterindustries.com/GrovePi/sensors/supported-sensors/ page but was wondering if you have any supporting documentation or code to help get the latching relay working?
Thanks.
karan
The relay can be used in the same way as a LED. If you send it a HIGH signal, it’ll turn the relay on, if you send a low signal, it’ll turn the relay off. You can use this as an example https://github.com/DexterInd/GrovePi/blob/master/Software/Python/grovepi_blink.py to use the relay.
Thanks Karan, great support
I’ll try it out and let you know how it goes!
