I am using grovepi+ to connect the grove dust sensor to raspberry pi 3.
The grove pi works fine and its Firmware version is 1 4 0.
The problem is grove dust sensor stops reading after few reading ( 4 time at max) and exit from the program and go o the main command . it seems that it is disabled. any help would be appreciated.
Thanks.
It seems the DI folks are busy. In the mean time:
Have you updated and rebooted your software?
Which OS are you using (DexterOS or RaspbianForRobots)?
(I don’t know anything about GrovePi …; On the GoPiGo3 DI made some changes in the way they handled I2C communication and I had a similar issue )
It sounds like you need @RobertLucian or @cleoqc
