sam
November 3, 2015, 3:19pm
Hi
Can you provide me a example for the Grove Encoder (D2) connected to GrovePi+ board?
I tried following code but I always receive zeros.
import time
import grovepi
import atexit
atexit.register(grovepi.encoder_dis)
print "Reading from the encoder"
grovepi.encoder_en()
try:
[new_val,encoder_val] = grovepi.encoderRead()
if new_val:
print encoder_val
time.sleep(.5)
except IOError:
print ("Error")"
and this is definations;
"def encoder_en():
write_i2c_block(address, encoder_en_cmd + [unused, unused, unused])
time.sleep(.2)
def encoder_dis():
write_i2c_block(address, encoder_dis_cmd + [unused, unused, unused])
time.sleep(.2)
def encoderRead():
write_i2c_block(address, encoder_read_cmd + [unused, unused, unused])
time.sleep(.2)
data_back= bus.read_i2c_block_data(address, 1)[0:2]
#print data_back
if data_back[0]!=255:
return [data_back[0],data_back[1]]
else:
return [-1,-1]
If you can also suggest how to change D2 to other port to test the GrovePi+ or Grove encoder has a problem.
Thank you
karan
November 3, 2015, 11:11pm
The Grove encoder only works with firmware version 1.2.5 and up. Can you make sure that you have it on your Pi: https://github.com/DexterInd/GrovePi/tree/master/Firmware/Source/v1.2/grove_pi_v1_2_5 and run a firmware update to upload it to the Atmega using: avrdude -c gpio -p m328p -U flash:w:grove_pi_v1_2_5.cpp.hex . After uploading the firmware, make sure that it is on there by running: https://github.com/DexterInd/GrovePi/blob/master/Software/Python/grove_firmware_version_check.py . Once the firmware is updated, connect the encoder to port D2 and try running this https://github.com/DexterInd/GrovePi/blob/master/Software/Python/grove_encoder_read.py .
Do let us know if this helps.
sam
November 3, 2015, 11:15pm
Hi Karan,
Can you please give instructions for uploading firmware.
karan
November 4, 2015, 12:04am
4
Hey Sam,
Make sure that you have the latest version of the GrovePi repository on the Raspberry Pi.
Go to the firmware folder: Grovepi/Firmware/Source/v1.2/grove_pi_v1_2_5 . It should look like this: https://github.com/DexterInd/GrovePi/tree/master/Firmware/Source/v1.2/grove_pi_v1_2_5 .
Double-check that this file is there: grove_pi_v1_2_5.cpp.hex
Run the firmware update using: avrdude -c gpio -p m328p -U flash:w:grove_pi_v1_2_5.cpp.hex.
Once the firmware update is done, run the grove_firmware_version_check.py in the Grovepi/Software/Python folder and make sure that it shows 1.2.5.
sam
November 4, 2015, 12:09am
5
mirar
November 4, 2015, 5:17pm
6
Not since you have a GrovePi+. The old GrovePi-without-plus needed that to be able to be flashed with avrdude.
sam
November 4, 2015, 7:00pm
7
Thank you Karan & Mirar,
Can you please advice how do I port Grove encoder to D3 or D4 port?
Thank you
I manage to update firmware sucessfully.
karan
November 4, 2015, 11:23pm
8
Hey Sam,
The Grove encoder can only work on Port 2 because it needs interrupts to work and the pins on Port 2 are the only ones that support it.
