import subprocess
debug =0
def send_command(bashCommand):
process = subprocess.Popen(bashCommand.split(), stdout=subprocess.PIPE) #, stderr=subprocess.PIPE)
output = process.communicate()[0]
return output
def check_ir():
flag=0
if ‘lirc_dev’ in open(’/etc/modules’).read():
flag=1
if debug:
print “lirc_dev in /etc/modules”
if 'lirc_rpi gpio_in_pin=15' in open('/etc/modules').read():
flag=1
if debug:
print "lirc_rpi gpio_in_pin=15 in /etc/modules"
if 'lirc_rpi gpio_in_pin=14' in open('/etc/modules').read():
flag=1
if debug:
print "lirc_rpi gpio_in_pin=14 in /etc/modules"
if 'dtoverlay=lirc-rpi,gpio_in_pin=14' in open('/boot/config.txt').read():
flag=1
if debug:
print "dtoverlay=lirc-rpi,gpio_in_pin=14 in /boot/config.txt"
if 'dtoverlay=lirc-rpi,gpio_in_pin=15' in open('/boot/config.txt').read():
flag=1
if debug:
print "dtoverlay=lirc-rpi,gpio_in_pin=15 in /boot/config.txt"
if flag:
return True
return False
def replace_in_file(filename,replace_from,replace_to):
f = open(filename,‘r’)
filedata = f.read()
f.close()
newdata = filedata.replace(replace_from,replace_to)
f = open(filename,'w')
f.write(newdata)
f.close()
def disable_ir():
if check_ir()==True:
if debug:
print “Disabling IR"
replace_in_file(’/etc/modules’,“lirc_dev”,”")
replace_in_file(’/etc/modules’,“lirc_rpi gpio_in_pin=15”,"")
replace_in_file(’/etc/modules’,“lirc_rpi gpio_in_pin=14”,"")
replace_in_file(’/boot/config.txt’,“dtoverlay=lirc-rpi,gpio_in_pin=14”,"")
replace_in_file(’/boot/config.txt’,“dtoverlay=lirc-rpi,gpio_in_pin=15”,"")
else:
if debug:
print “IR already disabled”
def enable_ir():
if debug:
print "lirc_dev already in /etc/modules"
else:
if debug:
print “lirc_dev added”
with open('/etc/modules', 'a') as file:
file.write('lirc_dev\n')
if debug:
print "lirc_rpi gpio_in_pin=15 already in /etc/modules"
else:
if debug:
print "lirc_rpi gpio_in_pin=15 added"
file.write('lirc_rpi gpio_in_pin=15\n')
if debug:
print "dtoverlay=lirc-rpi,gpio_in_pin=15 already in /boot/config.txt"
else:
if debug:
print "dtoverlay=lirc-rpi,gpio_in_pin=15 added"
with open('/boot/config.txt', 'a') as file:
file.write('dtoverlay=lirc-rpi,gpio_in_pin=15\n')
if name == “main”:
print check_ir()
#disable_ir()
#enable_ir()
