Hey mitch,
Thanks for the feedback about the sensor mounts. We’ll take these into consideration when we are doing the next iteration of the Grove Pi case and the sensor mount. Any suggestions on what we should do to make them work for everyone.
I’ll test the code in a bit and let you know how it goes.
I found an issue in the IO Exception handler in iotREST.py - the Ethernet interface name was incorrect. It was causing the autostarted code to crash occasionally. btw; the avrdude command indeed resets the GrovePi board - so I now have it run that command if I get 10 exceptions in a row.
My thought on the sensor design is a connector that is parallel to the circuit board (like the one on the RGB display) on either the top or ideally on the bottom of the board (side away from the sensor). Obviously you would need a cutout in the sensor mount to make that work, which would be an issue, given the different sizes and shapes of the sensor circuit boards.
As previously noted, I came up with a custom case as a version 1 experiment - pictures attached for your amusement.
Sorry for bringing up an old topic…
I am also facing the Grovepi+ RST issue.
It happens since I added a 2-Coil Latching Relay to the Grovepi+ board.
The relay is used to turn on and off a car wiper motor (powered by an external 12V source).
My test program turns it on for 5 seconds every minute.
It works fine for a couple of cycles (say 1-3 times, can vary), then the RST led turns red and every subsequent calls triggers IOException.
It’s always the call grovepi.digitalWrite(Relay,0) to turn the motor off that raises the RST.
I also tried the demo program, it causes the same effects.
It also happens that the call to turn off the motor does not work (the call itself works but the relay doesn’t switch). I don’t know if this is related to the RST issue.
“avrdude” restores correctly the board.
I ran “gpio readall” before and after a run of my programm. The result is attached.
I suspected electromagnetic parasites causing interference; So I enclosed the Grovepi+ in a mini Faraday cage: It did not work better.
I tried grove_2_coil_latching_relay.py; the error is the same:
sudo python grove_2_coil_latching_relay.py
on
off
IOError
on
IOError
off
^CIOError
The only modification I had to do is change the port number from 4 to 3, because D4 is taken by chainable LEDs
Here's my program.
I noticed one strange thing... In my program (function Open_Door1()), when I turn the motor ON, I turn a LED ON and turn is back OFF when switching the motor OFF. Then, when the relay fails switching OFF, the LED also doesn't turn OFF. Probably because the board is already in a bad state...
I have a second relay, tried it with the same result with both programs: Either hangs the board or refuses to switch off.
He Benoit,
That is a pretty big project you have there. Can you run the troubleshooting script following the instructions here: https://www.youtube.com/watch?v=MJu8k-_UQgg and upload the log here. Can you also disconnect the RGB LED’s before you start. Also, does the Relay work after you get the IOError’s or does it stop responding at all. The LED’s do have some problem but we are moving towards a fix (Read here for more details: http://www.dexterindustries.com/topic/chainable-leds).
Thanks for the clues.
The read errors mentionned in the chainable LED topic you pointed look pretty much like my experience. As you maybe have noticed in my code, I had to perform the sensor readings in loops until getting a valid value. Just because error were occurring several times a minute (my sensor reading rate is every 2 seconds).
To reply to your question, Yes, after the IOerror occur, the relay doesn’t work anymore; as well as the other sensors.
My code had a global boolean variable (WithLEDs) that I used to skip all portions of code dealing with LEDs. Setting it to false didn’t make the issue disappear.
Anyways, I was about to disconnect the LEDs and remove the according parts of my code as you suggested (they aren’t required in my project).
That’s the moment my GrovePi+ board chose to fail, preventing the Pi from booting.
I have now to figure out why, since the Pi boots correctly without the GrovePi+ plugged.
I couldn’t try the GoPiGo test program either.
And yes it’s a rather big project. It’s meant to manage a hen house : Doors opening and closing at dawn and dusk, water and seed provision automated, temperature control, camera, etc…
So, I need a reliable system coz I don’t want to have to get up at 5 AM to open the doors manually because of a failing relay
Hi Benoit,
Thanks for the information and sorry for the troubles you are facing. To solve this, it might be best to stat small and then slowly keep on adding the sensors until you encounter what fails. I would suggest you to disconnect everything from the GrovePi and then connect it to the Pi and power it on and see if it works. If the Pi powers on correctly, then run the troubleshooting script and upload the log on the forums so that I can look if there is anything wrong with the hardware (instructions here: https://www.youtube.com/watch?v=MJu8k-_UQgg).
All the best for your project too and we’ll try our best to help you out with any problems you face. It would be great if you could share the details/pictures of the project once its completed.
I started my project adding one sensor at a time. Trouble started when adding the relay.
Nevertheless, I unplugged everything from the GrovePi and the Pi could boot.
Where can I download the troubleshooting script mentionned in the video? As I don’t have a GoPiGo bundle…
Could the power supply be an issue?
By any chance would you have and idea of the required power supply for:
RPi2
GrovePi+
Wifi dongle
Temp+humidity, light, air quality sensors
3 chainable LEDs
1 buzzer
1 2-Coil Latching Relay
And I still have to add :
1 RPi camera
My power supply delivers 1 AMP. Maybe it’s not enough?
I plugged only the relay to the GrovePi+ and ran grove_2_coil_latching_relay.py.
The IOerror still occurs after only one on-off cycle, then the RST LED turns red.
I tried my 2 relays with the same result.
BTW, in this case the power supply cannot be the problem.
In the mean time, I abandonned the Raspberry/GrovePi solution. Both hardware and software seem not reliable enough for my needs and I haven’t even tried the behaviour in an outdoor environment.
So, I made the choice of a full hardware and industial solution (http://gce-electronics.com/en/din-web-relay-board-server/994-lan-controller-web-relay-board-ipx800-v4.html).
Sorry I made you lose your time and many thanks for the help.
Hey Benoit,
Really sorry to hear that the GrovePi and the sensors were not upto your expectation and you had to switch to another platform. Can you keep us posted on your experience with the other platform that you are switching to and also let us know if there is anything we could have done better. We’ll try to add better support and documentation for people who try to use multiple sensors.
I’ll give you a feedback on my implementation with the other platform, for sure (it’ll take a few weeks).
There is nothing to blame with support. I can see that you guys are doing your best to solve issues.
And yes, documentation could be improved with more complex or “real-life” examples". I also would have appreciated more details about the functions (parameters, return values, error handling,…)
Thanks again for the support.
Hello
I’m a new GrovePI user and by the way new on this site
sorry to wake this subject , but I have exactly the same problem.
sometime , when I activate one relay , the grovepi board goes to RST (with the red light) and I loose the input/output.
Strange thing, I tried to use another GPIO port on the raspberry in order to activate my relay (one unused by the grovepi). in this case, when I change the state of the relay directly connected on a separate PIN , the grovepi board revives !
( I mean the RST red light disappair and the input/output become available)
not each time, but if I switch the relay 3 or 4 times , I retrieve the grovepi
the command line “avrdude -c gpio -p m328p” solve the problem temporary , but I cannot use a script to launch it every time that the problem appear…
My project target wil contain arround 5 DHT11, 16 relays, 2 ultrasonic sensors and 2 analog temp sensors ; but currently I’m blocked with 2 relays only…
by any chance, did you solve this issue ?
BR
Stephane
first thing , on my project I mapped only the PIN needed between the raspberry and the GrovePI board ( describe in the post What are the GPIO mapping to the GrovePi+ Ports ) so only 5v, 3;3V, Gnd and 0,1,8,9,10,11,14,15 are linked. the rest is used as GPIO as output mode ( 4 5 6 12 13 16 17 18 19 20 21 22 23 24 25 26).
I try to give you a picture of the connections this week-end.
concerning the code / image , the install is :
raspbian Linux garage 4.4.13-v7+ as OS
Jeedom for the supervision/scenario/domotic system
so jeedom just launch directly the python script gave with the grovepi install. I don"t script anything else.
By exemple , Jeedom check each minute through your script grove_dht_pro.py and when the humidity is higher than 70% , Jeedom start my bathroom airing with the command line “gpio -g write 20 0” or “gpio -g write 20 1”
sometime, when Jeedom close the relay connected on the GPIO 20 , the RST appear on the grovepi board , and I loose the DHT11 sensor values until I reboot the raspberry or I send the magic command avrdude -c gpio -p m328p
I tried to connect CE0 ( GPIO 8 is the reset PIN isn’t it ?) on Ground or 3,3V , without success.
I hope than it is most clear for you…
I don’t understand why when I move one GPIO not linked on the GrovePI , I loose the card…
I am a bit confused, which pins you are using, can you point to me the pins you are using based on the labeling given here.
Can you also clarify what you mean by "I loose the card .." which is in the last line of your reply.
We haven’t used the OS that you are using and it will be better to help, if you could share with us the specifications of the relay and the details of the Power supply that you are using.
I just encounter the same issue with my Pi with a GrovePi+ piloting 3 (yep, three) Grove SPDT Relay (30A) + one lcd.
The problem definitely raise when power supply is not powerful enough, one with 0.88mAh always gives the RST issue…
But I do not have any error while running my Python script (only the fact my relay are not switching, but display is displaying what I ask…):
grovepi.pinMode(relay,“OUTPUT”)
grovepi.digitalWrite(relay,1)
So my questions are :
how can I get an error and trap it ?
I didn’t catch your command to reset the Grove board
@herrmann,
The Grove SPDT Relay takes a lot of current, around 200mA each, so you definitely need a very beefy 5V adapter to power it. Normal USB power from the computer won’t be very useful. You should use atleast a 5V 2A adapter. Also, I am not sure if it would still be able to handle 3 or more of those together.
To test this, just connect one of the relays to the board and run the python example and see if the relay turns on and off. This relay is pretty much like an LED, when you give 5V to the signal line, it turns ON. There is not a lot of feedback from the relay.
The command to reset the board is: avrdude -c gpio -p m328p
