Grove Pi Temp and humidity sensor
I’m using the Brickpi image. Sensor is Temp and humidity sensor.
I modified the grove_dht_pro.py for dht as follows
GrovePi + Grove Temperature & Humidity Sensor Pro
http://www.seeedstudio.com/wiki/Grove_-_Temperature_and_Humidity_Sensor_Pro
import grovepi
Connect the Grove Temperature & Humidity Sensor Pro to digital port D4
SIG,NC,VCC,GND
sensor = 7
try:
[temp,humidity] = grovepi.dht(sensor,0) <------------- using 0 instead of 1
print “temp =”, temp, " humidity =", humidity
except IOError:
    print "Error"
On running this, getting following log…
temp = 25.0 humidity = 46.0
temp = 26.0 humidity = 46.0
IOError
File “tarak_dht.py”, line 12, in <module>
TypeError: ‘int’ object is not iterable
What is the reason of IOError ? How to fix this?
The IOError shows up if the GrovePi loses a data packet when communicating with the RaspberryPi. It is nothing much to worky about and you should just add an exception handler to catch the TypeError and move on, something like except TypeError: pass.
