GROVE PI? USE THIS OPERATING SYSTEM: Archived 32-bit Pi OS Legacy
Only the archived 32-bit Pi OS Legacy is tested/recommended as base for the GrovePi,
Disclaimer: I do not own a GrovePi+ but everyone that tried this has been successful…
NOTE: Will not work for Raspberry Pi 5
  1. Download the archived Legacy PiOS 32-bit (Image date: May 3, 2023)
    The image to download is: 2023-05-03-raspios-buster-armhf.img.xz
  • Use Raspberry Pi Imager
    • Choose OS → CUSTOM → choose your downloaded archived Legacy PiOS 32-bit file
  • Set it up to connect to your network, select username: pi <–very important
  • Make sure it is fully working
    • setup with attached monitor or remote shell or VNC to the desktop
  1. Follow the GrovePi Setup instructions
sudo reboot
And if you get a “No module di_i2c” try:
and reboot.
