Grove Pi with Raspberry Pi camera
I am working on a Smart Home Project and among the components i am using are Raspberry Pi Model B+ with Pi Camera and Grove Pi, May i get Python Codes to work out Pi camera with Grove Pi?
Thank you.
What are you trying to do with the camera?
Just taking picture when motion is detected, I am using PIR motion sensor too,
Thank you.
The Pi camera and the GrovePi should work independentaly.
Once you are able to use python to take a picture (there should be some examples available oin the internet) and also get a python code to use the PIR sensor https://github.com/DexterInd/GrovePi/blob/master/Software/Python/grove_pir_motion_sensor.py you can just combine then together so that the camera is triggered by the PIR sensor.
There is some great information from the Pi Foundation on using the Pi Camera with Python here: https://www.raspberrypi.org/documentation/usage/camera/python/README.md
A great place to start with the Pi Camera. As Karan notes, you can then integrate it with some of the Grove sensors.
John
Thank you guys, i appreciate all your contributions!
I am working on the solutions you provided.
Thank you guys, it worked out pretty well!
