Grove Temperature Sensor
Yeah. The temp/hum sensor does not seem to return valid values…
Hey Radman, can you give us a little more detail? Are you getting values at all? What sensor are you using?
Hi, I had a similar problem.
For me the solution was really simple: i used the code of the dhtpro sensor while using the standar one, as a results temperature was around 600 and humidity around 1100.
try to change
[ temp,hum ] = dht(dht_sensor_port,1)
with
[ temp,hum ] = dht(dht_sensor_port,0)
Let me know if anything change!
Davide
