I tried to swich digital pin 4 with your Grove_-_2-Coil_Latching_Relay.py script.
Sometimes it prints that the pin is switched on or off without changing the the state of the pin, looks like your exception handling doesn’t work correct.
I have to check the pin after i switched it to be sure it really switched.
#!/usr/bin/env python
import time
import grovepi
ON = 'on’
OFF = ‘off’
relay = 4
def readPin(args):
pinStatus = grovepi.digitalRead(args)
if pinStatus == 0 or pinStatus == 1:
#print pinStatus
return pinStatus
break
else:
#print 'IOError’
time.sleep(0.3)
def writePin(pin, args):
if args == ‘off’:
grovepi.digitalWrite(pin,0)
time.sleep(0.3)
y = readPin(pin)
#print y
if y == 1:
print "IOError"
time.sleep(0.3)
elif y == 0:
print ‘pin:’, pin, args
break
elif args == ‘on’:
grovepi.digitalWrite(pin,1)
time.sleep(0.3)
y = readPin(pin)
#print y
if y == 0:
print "IOError"
time.sleep(0.3)
elif y == 1:
break
a = raw_input(‘Type on or off to switch relay:n’)
if a == ON:
writePin(relay, ON)
elif a == OFF:
writePin(relay, OFF)
