GrovePi - Alcohol Sensor reading problem
I am trying to build alcohol sensor, with GrovePi Alcohol sensor (Seeed Studio).
The problem is when sensor is disconnected from the board getting reading between 0 to 150.
but when sensor is connected to the board getting constant reading 1023.
I am using following python code:
import time
import grovepi
hcho_sensor = 0
grovepi.pinMode(hcho_sensor,“INPUT”)
grove_vcc = 5
try:
# Get sensor value
sensor_value = grovepi.analogRead(hcho_sensor)
    # Calculate voltage
    voltage = (float)(sensor_value * grove_vcc / 1024)
    print ("sensor_value =", sensor_value, " voltage =", voltage)
    time.sleep(.5)
except IOError:
    print ("Error")
That reading seems to indicate that the sensor is maxing out. It looks like your analog port is working fine. You may want to try to replace the sensor.
