I was not able to get any of the samples to work, so I did a software update and then tried to do a firmware update which failed to connect.
I ran troubleshooting
heck space left
/dev/root 3.6G 3.0G 416M 88% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 6.1M 425M 2% /run
/dev/mmcblk0p1 63M 21M 43M 33% /boot
tmpfs 87M 0 87M 0% /run/user/1000
Check for dependencies
git 1:2.1.4-2.1+deb8u5 install ok installed
arduino 2:1.6.0 install ok installed
minicom 2.7-1+deb8u1 install ok installed
wiringPi Not Found (ERR)
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Copyright (c) 2012-2015 Gordon Henderson
Raspberry Pi Details:
* Device tree is enabled.
*--> Raspberry Pi 3 Model B Rev 1.2
* This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 005: ID 046d:c077 Logitech, Inc.
Bus 001 Device 004: ID 04b3:3025 IBM Corp. NetVista Full Width Keyboard
|__ Port 4: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 5: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
V 7.3
This version of Raspbian was modified by Dexter Industries on the Jessie Raspbian Build.
This version was updated on 2017.09.28
Hostname
dex
Checking for Atmega chip
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
this check.
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00: -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
File "/home/pi/Dexter/GrovePi/Software/Python/grove_firmware_version_check.py", line 40, in <module>
print("GrovePi has firmware version: %s" %grovepi.version())
File "/home/pi/Dexter/GrovePi/Software/Python/grovepi.py", line 266, in version
return "%s.%s.%s" % (number[1], number[2], number[3])
TypeError: 'int' object has no attribute '__getitem__'
Hi @tremblayst,
It looks like your I2C is not enabled on your Raspberry Pi.
Can you run sudo raspi-config, then go to Advanced Options and finally enable the I2C interface? Doing this should enable your I2C. You can then check the connectivity to your GrovePi by running the troubleshooter again.
As a side note, the reason you can’t communicate with the GrovePi is because the sudo curl -kL dexterindustries.com/update_grovepi | bash command hasn’t been run or because it didn’t get through all of it.
Please let us know if the provided solution helped you.
I enabled it in raspi-config under advanced options, but I am still getting the same error in the troubleshooter. Could there be something wrong with my pi3?
I also ran the grovepi update. It completed.
access control disabled, clients can connect from any host
pi@dex:~ $ sudo curl -kl https://raw.githubusercontent.com/DexterInd/GrovePi/master/Script/update_grovepi.sh | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 1303 100 1303 0 0 7302 0 --:--:-- --:--:-- --:--:-- 7320
GrovePi Directory Exists
HEAD is now at 9dabb50 hotfix - added support for python 3 (#381)
Already up-to-date.
Working from main branch.
--> Start GrovePi update install.
_____ _
| __ \ | |
| | | | _____ _| |_ ___ _ __
| | | |/ _ \ \/ / __/ _ \ '__|
| |__| | __/> <| || __/ |
|_____/ \___/_/\_\\__\___|_| _
|_ _| | | | | (_)
| | _ __ __| |_ _ ___| |_ _ __ _ ___ ___
| | | '_ \ / _\ | | | / __| __| '__| |/ _ \/ __|
_| |_| | | | (_| | |_| \__ \ |_| | | | __/\__ \
|_____|_| |_|\__,_|\__,_|___/\__|_| |_|\___||___/
_____ _____ _
/ ____| | __ (_)
| | __ _ __ _____ _____| |__) |
| | |_ | '__/ _ \ \ / / _ \ ___/ |
| |__| | | | (_) \ V / __/ | | |
\_____|_| \___/ \_/ \___|_| |_|
Welcome to GrovePi Installer.
Requirements:
1) Must be connected to the internet
2) This script must be run as root user
Steps:
1) Installs package dependencies:
- python-pip alternative Python package installer
- git fast, scalable, distributed revision control system
- libi2c-dev userspace I2C programming library development files
- python-serial pyserial - module encapsulating access for the serial port
- python-rpi.gpio Python GPIO module for Raspberry Pi
- i2c-tools This Python module allows SMBus access through the I2C /dev
- python-smbus Python bindings for Linux SMBus access through i2c-dev
- python3-smbus Python3 bindings for Linux SMBus access through i2c-dev
- arduino AVR development board IDE and built-in libraries
- minicom friendly menu driven serial communication program
- numpy is the fundamental package for scientific computing with Python
2) Clone, build wiringPi in GrovePi/Script and install it
3) Removes I2C and SPI from modprobe blacklist /etc/modprobe.d/raspi-blacklist.conf
4) Adds I2C-dev, i2c-bcm2708 and spi-dev to /etc/modules
5) Installs gertboard avrdude_5.10-4_armhf.deb package
6) Runs gertboard setup
- configures avrdude
- downloads gertboard known boards and programmers
- replaces avrsetup with gertboards version
- in /etc/inittab comments out lines containing AMA0
- in /boot/cmdline.txt removes: console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1
- in /usr/share/arduino/hardware/arduino creates backup of boards.txt
- in /usr/share/arduino/hardware/arduino creates backup of programmers.txt
Special thanks to Joe Sanford at Tufts University. This script was derived from his work. Thank you Joe!
Raspberry Pi wil reboot after completion.
Check for internet connectivity...
Connected to the Internet
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Reading package lists... Done
Installing Dependencies
Building dependency tree
Reading state information... Done
git is already the newest version.
minicom is already the newest version.
python-dev is already the newest version.
python-pip is already the newest version.
python-serial is already the newest version.
i2c-tools is already the newest version.
libi2c-dev is already the newest version.
python-smbus is already the newest version.
python3-smbus is already the newest version.
arduino is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 230 not upgraded.
The following packages will be REMOVED:
python-rpi.gpio*
0 upgraded, 0 newly installed, 1 to remove and 230 not upgraded.
After this operation, 103 kB disk space will be freed.
(Reading database ... 94109 files and directories currently installed.)
Removing python-rpi.gpio (0.6.3~jessie-1) ...
python3-rpi.gpio*
After this operation, 182 kB disk space will be freed.
(Reading database ... 94099 files and directories currently installed.)
Removing python3-rpi.gpio (0.6.3~jessie-1) ...
The following NEW packages will be installed:
python-rpi.gpio
0 upgraded, 1 newly installed, 0 to remove and 230 not upgraded.
Need to get 0 B/23.5 kB of archives.
After this operation, 103 kB of additional disk space will be used.
Selecting previously unselected package python-rpi.gpio.
(Reading database ... 94087 files and directories currently installed.)
Preparing to unpack .../python-rpi.gpio_0.6.3~jessie-1_armhf.deb ...
Unpacking python-rpi.gpio (0.6.3~jessie-1) ...
Setting up python-rpi.gpio (0.6.3~jessie-1) ...
python3-rpi.gpio
Need to get 0 B/28.2 kB of archives.
After this operation, 182 kB of additional disk space will be used.
Selecting previously unselected package python3-rpi.gpio.
(Reading database ... 94097 files and directories currently installed.)
Preparing to unpack .../python3-rpi.gpio_0.6.3~jessie-1_armhf.deb ...
Unpacking python3-rpi.gpio (0.6.3~jessie-1) ...
Setting up python3-rpi.gpio (0.6.3~jessie-1) ...
python-scipy is already the newest version.
python3-scipy is already the newest version.
Requirement already up-to-date: RPi.GPIO in /usr/lib/python2.7/dist-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): numpy in /usr/lib/python2.7/dist-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): numpy in /usr/lib/python3/dist-packages
Cleaning up...
Dependencies installed
wiringPi VERSION is 236
FOUND WiringPi Version 2.36 No installation needed.
Adding I2C-dev and SPI-dev in /etc/modules . . .
I2C-dev already present
i2c-bcm2708 already present
spi-dev already present
Making I2C changes in /boot/config.txt . . .
i2c1 already present
i2c_arm already present
adduser: The group `i2c' already exists.
Installing avrdude
/home/pi/Dexter/lib/AVRDUDE Found!
avrdude 5.10 Found
done with AVRDUDE
Install python libraries
If you see errors related to /etc/inittab, it's fine.
/etc/inittab has been deprecated in favor of systemd,
cfr. https://www.raspberrypi.org/forums/viewtopic.php?f=66&t=123081
Making libraries global . . .
Done
Please restart the Raspberry Pi for the changes to take effect
Please restart to implement changes!
_____ ______ _____ _______ _____ _______
| __ \| ____|/ ____|__ __|/\ | __ \__ __|
| |__) | |__ | (___ | | / \ | |__) | | |
| _ /| __| \___ \ | | / /\ \ | _ / | |
| | \ \| |____ ____) | | |/ ____ \| | \ \ | |
|_| \_\______|_____/ |_/_/ \_\_| \_\ |_|
To Restart type sudo reboot
Hi @tremblayst,
Okay, so after you ran the update (sudo curl -kL dexterindustries.com/update_grovepi | bash), you still weren’t being able to interface with your GrovePi? That’s a bit peculiar.
If it still doesn’t work for you, can you tell us:
If you’re using the Jessie or the Stretch distro?
What the command uname -a outputs?
What the i2cdetect -y 1 command ouputs?
Jessie
pi@dex:~ $ uname -a
Linux dex 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
pi@dex:~ $ i2cdetect -y 1
70: – -- – -- – -- – --
