I saw several similar threads about this topic, however, I am unable to get the recommendations from previous responses to resolve my issue.
This is a new install. I have downloaded & booted to 2019.04.05_Raspbian_For_Robots_by_Dexter_Industries_Stretch
as my starting point.
The install all appears to work properly, no obvious errors in log review. Updates appear to work. When I run the “sudo python grove_led_blink.py” line with my led plugged into D4, the light does not blink.
Here is the output from the log file & my pic of the install.
Check space left
/dev/root 59G 3.7G 54G 7% /
devtmpfs 433M 0 433M 0% /dev
tmpfs 438M 5.8M 432M 2% /dev/shm
tmpfs 438M 12M 426M 3% /run
tmpfs 438M 0 438M 0% /sys/fs/cgroup
/dev/mmcblk0p1 42M 23M 19M 55% /boot
tmpfs 88M 4.0K 88M 1% /run/user/1000
Check for dependencies
python 2.7.13-2 install ok installed
python-pip 9.0.1-2+rpt2 install ok installed
git 1:2.11.0-3+deb9u4 install ok installed
libi2c-dev 3.1.2-3 install ok installed
python-serial 3.2.1-1 install ok installed
python-rpi.gpio 0.6.5~stretch-1 install ok installed
i2c-tools 3.1.2-3 install ok installed
python-smbus 3.1.2-3 install ok installed
arduino 2:1.0.5+dfsg2-4.1 install ok installed
minicom 2.7-1.1 install ok installed
find: â/run/user/1000/gvfsâ: Permission denied
find: â/proc/1064/task/1064/netâ: Invalid argument
find: â/proc/1064/netâ: Invalid argument
find: â/proc/1065/task/1065/netâ: Invalid argument
find: â/proc/1065/netâ: Invalid argument
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Raspberry Pi Details:
- Device tree is enabled.
*–> Raspberry Pi 3 Model B Rev 1.2 - This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 005: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 001 Device 004: ID 04f2:1060 Chicony Electronics Co., Ltd
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
|__ Port 3: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 5: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 5, If 2, Class=Human Interface Device, Driver=usbhid, 12M
Raspbian for Robots Version
V 9
This version of Raspbian was modified by Dexter Industries on the Jessie Raspbian Build.
This version was updated on 26th of June 2018.
Hostname
dex
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or /dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version
GrovePi has firmware version: 1.4.0
===== EOF =====
Thanks in advance for the suggestions.
Curtis
