My installation of the GrovePi+ with my Raspberry Pi doesn’t appear to be working. I think I followed exactly the steps listed, but the sensor/led tests are not working and I get errors logged when using “test and Troubleshoot”.
Can you help ?
Nicolas
Check space left
Sys. de fichiers Taille Utilisé Dispo Uti% Monté sur
/dev/root 13G 5.1G 7.2G 42% /
devtmpfs 460M 0 460M 0% /dev
tmpfs 464M 50M 414M 11% /dev/shm
tmpfs 464M 13M 452M 3% /run
tmpfs 464M 0 464M 0% /sys/fs/cgroup
/dev/mmcblk0p6 68M 22M 46M 33% /boot
tmpfs 93M 0 93M 0% /run/user/1000
/dev/mmcblk0p5 30M 398K 28M 2% /media/pi/SETTINGS
Check for dependencies
python 2.7.13-2 install ok installed
python-pip 9.0.1-2+rpt2 install ok installed
git 1:2.11.0-3+deb9u3 install ok installed
libi2c-dev 3.1.2-3 install ok installed
python-serial 3.2.1-1 install ok installed
python-rpi.gpio 0.6.3~stretch-1 install ok installed
i2c-tools 3.1.2-3 install ok installed
python-smbus 3.1.2-3 install ok installed
dpkg-query: aucun paquet ne correspond à arduino
dpkg-query: aucun paquet ne correspond à minicom
find: ‘/proc/662/task/662/net’: Argument invalide
find: ‘/proc/662/net’: Argument invalide
find: ‘/run/user/1000/gvfs’: Permission non accordée
wiringPi Not Found (ERR)
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.46
Copyright (c) 2012-2018 Gordon Henderson
Raspberry Pi Details:
Type: Pi 3+, Revision: 03, Memory: 1024MB, Maker: Sony
* Device tree is enabled.
*--> Raspberry Pi 3 Model B Plus Rev 1.3
* This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 004: ID 413c:2106 Dell Computer Corp. Dell QuietKey Keyboard
Bus 001 Device 005: ID 04b3:310c IBM Corp. Wheel Mouse
Bus 001 Device 006: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 2: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 1: Dev 6, If 0, Class=Vendor Specific Class, Driver=lan78xx, 480M
|__ Port 3: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
cat: /home/pi/di_update/Raspbian_For_Robots/Version: Aucun fichier ou dossier de ce type
Hostname
raspberrypi
Checking for Atmega chip
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00: -- 04 -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
GrovePi has firmware version: 1.2.7
