I have some errors as below. please look over it and give me some comments
GrovePi Troubleshooting Script
Adding permissions to the scripts
Check space left
/dev/root 15G 4.3G 9.7G 31% /
devtmpfs 459M 0 459M 0% /dev
tmpfs 463M 29M 435M 7% /dev/shm
tmpfs 463M 13M 451M 3% /run
tmpfs 463M 0 463M 0% /sys/fs/cgroup
/dev/mmcblk0p1 42M 21M 21M 50% /boot
tmpfs 93M 0 93M 0% /run/user/1000
Check for dependencies
python 2.7.13-2 install ok installed
python-pip 9.0.1-2+rpt1 install ok installed
git 1:2.11.0-3+deb9u2 install ok installed
libi2c-dev 3.1.2-3 install ok installed
python-serial 3.2.1-1 install ok installed
python-rpi.gpio 0.6.3~stretch-1 install ok installed
i2c-tools 3.1.2-3 install ok installed
python-smbus 3.1.2-3 install ok installed
arduino 2:1.0.5+dfsg2-4.1 install ok installed
minicom 2.7-1.1 install ok installed
find: ‘/run/user/1000/gvfs’: Permission denied
wiringPi Found
wiringPi Found
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Copyright (c) 2012-2015 Gordon Henderson
Raspberry Pi Details:
* Device tree is enabled.
*--> Raspberry Pi 3 Model B Rev 1.2
* This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
ttyAMA0
USB device status
Bus 001 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 004: ID 046d:c326 Logitech, Inc.
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
|__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 2: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 5: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 5, If 2, Class=Human Interface Device, Driver=usbhid, 12M
Raspbian for Robots Version
Hostname
raspberrypi
Checking for Atmega chip
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00: -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- ^C
pi@raspberrypi:~/Desktop/GrovePi/Troubleshooting $ sudo ./all_tests.sh
Check space left
wiringPi Found
wiringPi Found
Hardware revision
gpio version: 2.36
i2c-1
ttyAMA0
USB device status
Hostname
raspberrypi
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Checking I2C bus 0
Checking I2C bus 1
70: -- -- -- -- -- -- -- --
Checking for firmware version
File "/home/pi/Desktop/GrovePi/Software/Python/grove_firmware_version_check.py", line 40, in <module>
print("GrovePi has firmware version: %s" %grovepi.version())
File "/home/pi/Desktop/GrovePi/Software/Python/grovepi.py", line 266, in version
return "%s.%s.%s" % (number[1], number[2], number[3])
TypeError: 'int' object has no attribute '__getitem__'
