GrovePi examples not working. just getting error[SOLVED]
I ran the troubleshoot and test app and got the follow log file. Is this an easy to fix issue?
Check space left
/dev/root 3.6G 2.7G 712M 80% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 6.1M 425M 2% /run
/dev/mmcblk0p1 60M 21M 40M 35% /boot
tmpfs 87M 0 87M 0% /run/user/1000
Check for dependencies
python-rpi.gpio 0.6.2~jessie-1 install ok installed
arduino 2:1.0.5+dfsg2-4 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.32
Raspberry Pi Details:
  • Device tree is enabled.
  • This Raspberry Pi supports user-level GPIO access.
    -> ie. export WIRINGPI_GPIOMEM=1
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 005: ID 046d:c077 Logitech, Inc.
Bus 001 Device 004: ID 04b3:3025 IBM Corp. NetVista Full Width Keyboard
    |__ Port 3: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
    |__ Port 5: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
V 6.9
This version of Raspbian was modified by Dexter Industries on the Wheezy Raspbian Build.
This version was updated on 2016.05.09
Hostname
dex
Checking for Atmega chip
     Copyright (c) 2000-2005 Brian Dean,  http://www.bdmicro.com/
     Copyright (c) 2007-2009 Joerg Wunsch
     Using Port                    : unknown
     Using Programmer              : gpio
     AVR Part                      : ATMEGA328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : GPIO
     Description     : Use sysfs interface to bitbang GPIO lines
     this check.
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
00: 03 – -- – -- – -- – -- – -- – --
30: – -- – -- – -- – -- – -- – -- – -- 3e –
60: – -- 62 – -- – -- – -- – -- – -- – -- –
70: 70 – -- – -- – -- –
Checking for firmware version
File “/home/pi/Desktop/GrovePi/Software/Python/grove_firmware_version_check.py”, line 40, in
print("GrovePi has firmware version: %s" %grovepi.version())
File “/home/pi/Desktop/GrovePi/Software/Python/grovepi.py”, line 258, in version
return "%s.%s.%s" % (number[1], number[2], number[3])
TypeError: ‘int’ object has no attribute ‘getitem’
Hi @tremblayst,
It looks like the the Pi is unable to communicate with the GrovePi as the i2cdetect -y 1 is not showing the GrovePi address(04). So can you post a picture of the setup and also tell us what all sensors you have connected to the GrovePi.
You should remove all sensors connected to GrovePi and then try running the grove_firmware_version_check.py again.If it still does not work, then run the troubleshooting script again and post the log with your reply.
-Shoban
sorry for the late reply. I ended up re-imaging the SD card i got from dexter per their online instructions. I then did the update and upgrade commands. Now everything is working as expected. Maybe a got a bad install on my sd card or I screwed up some configuration.
This topic was automatically closed after 12 hours. New replies are no longer allowed.
