I’ve been using GrovePi for about a month.
Worked fine in conjunction with relays, temp sensors, etc.
Last week i ran a “sudo apt-get update” “sudo apt-get upgrade”.
After the update, no matter what script i’m trying to run i get this:
pi@raspberrypi ~ $ sudo python temp.py
File “temp.py”, line 2, in <module>
import grovepi
File “build/bdist.linux-armv6l/egg/grovepi.py”, line 22, in <module>
IOError: [Errno 2] No such file or directory
The image i was using was the NOOBS one with the GrovePi libraries installed. I’ve tried reinstalling from scratch, same result.
Next i’ve tried with the Dexterindustries image, if i leave it as it comes, everything works fine. If i update, i get the same issue.
If, after updating, i run i2cdetect -y 1, i get:
Error: Could not open file /dev/i2c-1’ or/dev/i2c/1’: No such file or directory
Tried the script on the existing install, no change.
So i did the following:
1.clean install using the 2014.07.30_Dexter_Industries_wheezy image.
2.ran sudo i2cdetect -y 1 , output ok, grove was there.
3.sudo apt-get update
4.sudo apt-get upgrade (output attached)
5.ran sudo i2cdetect -y 1 , output ok, grove was there.
6.reboot
7.5.ran sudo i2cdetect -y 1 , got the error
8.ran the script (output attached)
9.ran sudo i2cdetect -y 1 , got the error
