I am new to the GrovePi. Just connected it to my Pi3 Model B and installed the Raspian for Robots on the CD. After boot the I2C test failed.
Here is the log. Any help is appreciated.
Best regards
Roland
Check space left
/dev/root 3.6G 2.7G 662M 81% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 6.2M 425M 2% /run
/dev/mmcblk0p1 63M 21M 43M 33% /boot
tmpfs 87M 0 87M 0% /run/user/1000
Check for dependencies
arduino 2:1.6.0 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Copyright Β© 2012-2015 Gordon Henderson
Raspberry Pi Details:
- Device tree is enabled.
*β> Raspberry Pi 3 Model B Rev 1.2 - This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 004: ID 0000:0538
Bus 001 Device 005: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
|__ Port 4: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 5: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
V 7.0
This version of Raspbian was modified by Dexter Industries on the Wheezy Raspbian Build.
This version was updated on 2016.10.05
Hostname
dex
Checking for Atmega chip
Copyright Β© 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright Β© 2007-2009 Joerg Wunsch
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or/dev/i2c/0β: No such file or directory
Checking I2C bus 1
00: β -- β -- β -- β -- β -- β -- β
10: β -- β -- β -- β -- β -- β -- β -- β --
20: β -- β -- β -- β -- β -- β -- β -- β --
30: β -- β -- β -- β -- β -- β -- β -- β --
40: β -- β -- β -- β -- β -- β -- β -- β --
50: β -- β -- β -- β -- β -- β -- β -- β --
60: β -- β -- β -- β -- β -- β -- β -- β --
70: β -- β -- β -- β --
Checking for firmware version
File β/home/pi/Desktop/GrovePi/Software/Python/grove_firmware_version_check.pyβ, line 40, in
print(βGrovePi has firmware version: %sβ %grovepi.version())
File β/home/pi/Dexter/GrovePi/Software/Python/grovepi.pyβ, line 265, in version
return β%s.%s.%sβ % (number[1], number[2], number[3])
TypeError: βintβ object has no attribute βgetitemβ
