GrovePi Python Issue
I am trying to use the basic Python libraries with the GrovePi. I have test one I had and kept getting the same error.
  File "dwPY_OpenMQTT.py", line 208, in <module>
    sensor_value = grovepi.analogRead(potentiometer);
  File "build/bdist.linux-armv7l/egg/grovepi.py", line 226, in analogRead
    return number[1] * 256 + number[2]
TypeError: 'int' object has no attribute '__getitem__'
Seems that even if I run the sample code that is supplied with the git, I get the same error.
pi@raspberrypi:~/Desktop/GrovePi/Software/Python/firmware_tests $ python multi_analog_read.py
  File "multi_analog_read.py", line 46, in <module>
    sensor_value0 = grovepi.analogRead(sensor0)
Script seems to run until it tries to perform the analogRead function.
Any help would be great.
Thanks in advance
in order to help you out more efficiently, could you run the script found in GrovePi/Troubleshooting. all_tests.sh and upload the log here ?
GrovePi Troubleshooting Script
Adding permissions to the scripts
Check space left
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       7.4G  1.5G  5.6G  21% /
devtmpfs        459M     0  459M   0% /dev
tmpfs           463M     0  463M   0% /dev/shm
tmpfs           463M  6.3M  457M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           463M     0  463M   0% /sys/fs/cgroup
/dev/mmcblk0p1   63M   21M   42M  33% /boot
tmpfs            93M     0   93M   0% /run/user/1000
Check for dependencies
arduino 2:1.0.5+dfsg2-4 install ok installed
dpkg-query: no packages found matching scratch
wiringPi Not Found (ERR)
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Copyright (c) 2012-2015 Gordon Henderson
Raspberry Pi Details:
  Type: Pi 3, Revision: 02, Memory: 1024MB, Maker: Embest
  * Device tree is enabled.
  *--> Raspberry Pi 3 Model B Rev 1.2
  * This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
ttyAMA0
USB device status
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
Raspbian for Robots Version
Hostname
mrbit
Checking for Atmega chip
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         Using Port                    : unknown
         Using Programmer              : gpio
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : GPIO
         Description     : Use sysfs interface to bitbang GPIO lines
avrdude: safemode: hfuse reads as DE
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00:          -- 04 -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
GrovePi has firmware version: 255.255.255
Log has been saved to Desktop. Please copy it and send it by email or upload it on the forums
I notice it states:
But I have enables I2C and SPI in raspi-config and I have got wiringPi installed.
The grovepi is working fine when the grovepi.py is in the same directory of the script I’m running, it’s not able to load modules (like pinMode) when used from the package.
Thanks.
Based on this log, you’re running the standard version of Raspbian and not Raspbian for Robots?
Did you follow the installation steps ?
It seems we posted at the same time.
It does seem like an install problem if grovepi.py works when in the same directory.
Run grovepi/script/install.sh to be certain.
ah in my haste I was reading from here https://github.com/initialstate/grovepi/wiki/Part-2.-GrovePi-Setup
I will pip uninstall grovepi to remove it from the dist-packages and test again.
tom
hmmm, thanks for the link there. The pip install will not work. The grovepi installation script already puts the module in the main python system library so it will be reachable from any directory.
Thanks for your help cloeqc - It’s all working now I’ve pip uninstall grovepi
(annoyingly I should have noticed that I was reading something from a wrong github acc).
Tom
Seems that the cause of my issue is different. I am running the install.sh script. I am running it via a script that I wrote. I have the snippet below. I am also running the python3 install script and the regular python setup.py file.
Seems that possibly the script is not successfully removing SPI and I2C off the blacklist.
cd /home/pi/Desktop
sudo git clone https://github.com/DexterInd/GrovePi
sudo chmod 777 /home/pi/Desktop/GrovePi/Script/install.sh
sudo chmod 777 /home/pi/Desktop/GrovePi/Script/grovepi_python3_install.sh
sudo bash /home/pi/Desktop/GrovePi/Script/install.sh
sudo bash /home/pi/Desktop/GrovePi/Script/grovepi_python3_install.sh
cd /home/pi/Desktop/GrovePi/Software/Python
sudo python setup.py install
When I get the chance, possibly monday, I can run the test scripts.
I am preforming a brand new installation on a brand new updated Raspbian.
  1. Created new SD card with latest Raspbian, 3-2-2017
  2. Connected to wifi and configured raspberry pi. Ran apt-get update && upgrade
  3. Followed your instructions to install GrovePi git
  4. ran all_tests.sh. Outcome below
I can re-run the install with a script and have that output to a log. But I am not doing anything special, at least not that I am aware of.
I can’t even check the firmware version of the grovepi as the python file fails.
Check space left
/dev/root 7.1G 4.3G 2.6G 63% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 4.0K 432M 1% /dev/shm
tmpfs 432M 6.0M 426M 2% /run
tmpfs 87M 0 87M 0% /run/user/1000
wiringPi Found
Hardware revision
gpio version: 2.36
  • Device tree is enabled.
    *–> Raspberry Pi 3 Model B Rev 1.2
  • This Raspberry Pi supports user-level GPIO access.
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 005: ID 046d:c077 Logitech, Inc.
Bus 001 Device 004: ID 413c:2107 Dell Computer Corp.
|__ Port 3: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 5: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Hostname
raspberrypi
     PAGEL                         : PD7
     BS2                           : PC2
     RETRY pulse                   : SCK
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
File “/home/pi/Desktop/GrovePi/Software/Python/grove_firmware_version_check.py”, line 40, in
print(“GrovePi has firmware version: %s” %grovepi.version())
File “/home/pi/Desktop/GrovePi/Software/Python/grovepi.py”, line 265, in version
return “%s.%s.%s” % (number[1], number[2], number[3])
TypeError: ‘int’ object has no attribute ‘getitem’
Seems I figured out one issue, the GrovePi was missing its firmware. Flashed the firmware to the GrovePi and now I have the i2cdetect showing the 4.
I am still having the all_tests.sh show some ERRs.
Check space left
wiringPi Found
Hardware revision
gpio version: 2.36
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Hostname
raspberrypi
     PAGEL                         : PD7
     BS2                           : PC2
     RETRY pulse                   : SCK
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
Checking I2C bus 0
Checking I2C bus 1
GrovePi has firmware version: 1.2.7
