Hi there, I have just bought a starter bundle, plugged it all in and installed, updated the firmware on the grovepi but I can’t get any sensors to work at all.
The LED screen lit up once - jut bright green nothing else but since then nothing at all has worked, any thoughts?
I’m wondering if it’s an install problem?
Check space left
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        13G  5.2G  7.0G  43% /
devtmpfs        460M     0  460M   0% /dev
tmpfs           464M     0  464M   0% /dev/shm
tmpfs           464M   13M  452M   3% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           464M     0  464M   0% /sys/fs/cgroup
/dev/mmcblk0p6   68M   22M   47M  33% /boot
tmpfs            93M     0   93M   0% /run/user/1000
/dev/mmcblk0p5   30M  398K   28M   2% /media/pi/SETTINGS
Check for dependencies
python 2.7.13-2 install ok installed
python-pip 9.0.1-2+rpt2 install ok installed
git 1:2.11.0-3+deb9u4 install ok installed
libi2c-dev 3.1.2-3 install ok installed
python-serial 3.2.1-1 install ok installed
python-rpi.gpio 0.6.5~stretch-1 install ok installed
i2c-tools 3.1.2-3 install ok installed
python-smbus 3.1.2-3 install ok installed
dpkg-query: no packages found matching arduino
dpkg-query: no packages found matching minicom
find: ‘/run/user/1000/gvfs’: Permission denied
find: ‘/proc/707/task/707/net’: Invalid argument
find: ‘/proc/707/net’: Invalid argument
wiringPi Not Found (ERR)
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.50
Copyright (c) 2012-2018 Gordon Henderson
Raspberry Pi Details:
  Type: Pi 3B+, Revision: 03, Memory: 1024MB, Maker: Sony
  * Device tree is enabled.
  *--> Raspberry Pi 3 Model B Plus Rev 1.3
  * This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
ttyAMA0
USB device status
Bus 001 Device 004: ID 045e:00db Microsoft Corp. Natural Ergonomic Keyboard 4000 V1.0
Bus 001 Device 005: ID 046d:c016 Logitech, Inc. Optical Wheel Mouse
Bus 001 Device 006: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
            |__ Port 1: Dev 6, If 0, Class=Vendor Specific Class, Driver=lan78xx, 480M
            |__ Port 3: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
        |__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
        |__ Port 2: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
Hostname
raspberrypi
Checking for Atmega chip
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         Using Port                    : unknown
         Using Programmer              : gpio
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : GPIO
         Description     : Use sysfs interface to bitbang GPIO lines
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00:          03 04 -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- 3e --
60: -- -- 62 -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
Checking for firmware version
GrovePi has firmware version: 1.3.0
