I’m just starting with GrovePi+ Starter Kit with Raspberry Pi B+, and trying the "LED brink tutorial! as follows:
http://www.dexterindustries.com/GrovePi/projects-for-the-raspberry-pi/raspberry-pi-led-tutorial/
But, the result of python script is as follows
pi@raspberrypi ~/MCC/GrovePi/Software/Python $ sudo python grove_led_blink.py
File "grove_led_blink.py", line 12, in <module>
from grovepi import *
File "/home/pi/MCC/GrovePi/Software/Python/grovepi.py", line 30, in <module>
bus = smbus.SMBus(1)
IOError: [Errno 2] No such file or directory
Also, the result of checking i2c is as follows
pi@raspberrypi ~/MCC/GrovePi/Software/Python $ sudo i2cdetect -y 1
Error: Could not open file <code>/dev/i2c-1' or</code>/dev/i2c/1': No such file or directory
pi@raspberrypi ~/MCC/GrovePi/Software/Python $ sudo i2cdetect -y 0
Error: Could not open file <code>/dev/i2c-0' or</code>/dev/i2c/0': No such file or directory
Do you have any idea about the possible cause? Thanks.
