I installed Raspbian for Robots on my Pi3, pluged the GrovePi Ultrasonic distance sensor :
but the python script is stuck, and when I launch the GrovePi troubleshooting, I get this :
Thank for your time
Thank for your time
Update :
Now I’m using the c++ version, grovepi_us_read.cpp
Now it returns a random value over and over evey time I launch it,
like : [pin 4][ultrasonic read = 43877 cm]
thanks
Please use Python3. There seems to be an issue with Python2. Are you running Buster?
no, Raspbian for Robots
I’m not using python anymore
Just my two cents here, but have you tried using the serial services/libraries with something else? - like maybe a serial display module or something?
As far as I can tell, reading the thread as it is, I don’t know if you are having a problem with the sensor or the serial port?
If I were doing this, I’d stop using the sensor, and then try something else on the same port, perhaps a serial display module, to see if the serial port itself is working.
I just tried the grovepi_us_read.cpp code and it works fine over here. (of course it would)
Did you ever get a proper output from sudo i2cdetect -y 1 ? cause if that fails, everything else will fail too
Also, I fixed an issue with installation moments ago, so you may want to re-install, if the i2cdetect still fails for you.
