GrovePi+: Trouble getting Grove Sensors working with Grove Python Library
I’m trying to learn IoT by working through this tutorial https://github.com/microsoft/IoT-For-Beginners.
I work with a GrovePi+ Starter Kit on a Raspberri 2 and installed Raspbian Buster. I installed the Python libraries from Seed by following the instructions given in the tutorial
sudo apt install git python3-dev python3-pip --yes
git clone https://github.com/Seeed-Studio/grove.py
cd grove.py
sudo pip3 install .
sudo raspi-config nonint do_i2c 0
I followed the instructions at DexterIndustries as well. Everything seemed to work fine.
I ran into some problems using the Python library from Seeed-Studio. When I run the example provided https://github.com/Seeed-Studio/grove.py/blob/master/grove/grove_light_sensor_v1_2.py
I always get the same results, while covering the sensor and uncovering…
The Output is:
Hat Name = ‘None’
Unknown hat, assuming Grove Base Hat RPi
Detecting light…
Light value: 65280
Light value: 65280
Light value: 65280
When using following code, the sensor seems to work properly:
light_sensor = 0
led = 5
     light = grovepi.analogWrite(led, 100)
     print("light level: ", light)
     if light < 300:
     else:
          grovepi.analogWrite(led, 0)
     time.sleep(1)
The LED turns on and off als intended. Again when using the library from Seeed to turn the LED on and off with following code:
from grove.grove_led import GroveLed
led = GroveLed(5)
led.on()
nothing happens.
Has anybody an idea how to get the Seeed library to work? Been struggling to get it working for a few days now and have no idea what else to try!
Thank you very much!
Did you install the Legacy OS?
Did you try the Dexter light sensor program?
Yes, the one with a desktop environment, if that matters.
Do you mean this one? https://github.com/DexterInd/GrovePi/blob/master/Software/Python/grove_light_sensor.py
I’ve tried and everything seems to work properly.
But I just don’t get the examples from Seeed-Studio to work… :confused:
I’d like to use libs from Seeed-Studio because of the more object-oriented approach.
