Update:
I searched for solutions, and tried the instruction from one post After Firmware update, one motor runs constantly on reboot,
I tried sudo bash firmware_update_v16.sh, and it seemed works. Gopigo is moving forward again~~
To make sure it’s really good now, I did the troubleshoot,
can anyone help check my latest log to see if anything is wrong now?
Check space left
/dev/root 3.6G 2.8G 615M 82% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 6.1M 425M 2% /run
/dev/mmcblk0p1 63M 21M 43M 33% /boot
tmpfs 87M 0 87M 0% /run/user/1000
Check for dependencies
python-rpi.gpio unknown ok not-installed
arduino 2:1.6.0 install ok installed
wiringPi Not Found (ERR)
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Raspberry Pi Details:
- Device tree is enabled.
*–> Raspberry Pi 3 Model B Rev 1.2
- This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version and CPU Speed and Voltage
v 1.6
CPU speed: 2
10.05 V
CHECKING ENCODER READINGS
0 0
Both motors moving Forward with LED On
after 5 sec 161 155
Both motors stopped with LED Off
None after stop cmd 167 160
None after 2 more sec 169 160
Both motors moving back with LED On
after 5 sec 282 262
None after stop cmd 282 262
None after 2 more sec 282 262
CHECKING ENCODER TARGETING
Initial encoder read vals: 0 0
Enc tgt Status: 1
Enc tgt Status: 0
Final encoder read vals: 0 0
Enc tgt Status: 1
Enc tgt Status: 1
File “/home/pi/Dexter/GoPiGo/Software/Python/tests/enc_tgt_test.py”, line 69, in
enc_stat=read_enc_status()
File “build/bdist.linux-armv7l/egg/gopigo.py”, line 610, in read_enc_status
File “build/bdist.linux-armv7l/egg/gopigo.py”, line 601, in read_status
