Home Weather Display No Module
Hello!
I’ve been following the directions here: https://www.dexterindustries.com/projects/home-weather-display/
When I attempt to execute the python program, I am hit with the following:
Traceback (Most Recent Call Last): File “Home_Weather_Display.py”, line 40, in from grovepi import * Import Error: no module named grovepi
I’ve tried other python scripts to test the connectivity of the grove pi, specifically grove_led_blink.py and that worked. Any ideas?
Hi @stephen.jablonski,
Well, it looks like the GrovePi is not installed on your image. Can you tell us if you’re running a fresh Rasbian or basically another image that’s not Raspbian For Robots?
Anyway, in order to have the grovepi package installed, please run the following command:
