Hello, I am building a driving robot and am having extreme difficulty getting the pivotpi, pivotpi battery pack, and BrickPi battery onto Lego’s. Since they have no direct way to connect, it is hard. I’m curious how do you guys do it?
Hey @graykevinb, We haven’t thought about this much before, but it’s a good question. The PivotPi is really meant to be attached to the Raspberry Pi . . . after that, we hadn’t contemplated what to do. Any suggestions?
I have had great sucess with just using a bit rubber band and doubling it over. I used this when using the orginial 8xAA cell battery pack and also my new LiIon battery pack see attached pic of my new blue coloured battery
I did find that I had to extend my original battery pack lead as it was a bit short and I also changed the plug to a elbow plug where it plugs into the BrickPi to make it more low profile and easier it fit on small compact robot
I know, this is a kind of old thread but I also have a question regarding how to assembly lego bricks. I would like to build around the case some lego bricks but it seems that the height of the BrickPi is not standard lego size. I mean when I put bricks on the roof and bottom I am not able to connect them of missing some millimeters to one direction on the site.
Regards
Stephan
Looks to me like the vertical member is sloped inward, (toward the left), slightly.
If it were my rig, I’d try moving that member out just a smidge to make the top holes line up.
I haven’t worked with this exact kind of Lego building stuff, but the stuff I’ve worked with in the past sometimes required a bit of “fitting” to make things fit.
It is really wired because usually Lego is designed that the bricks just match, so I am wondering if I did something wrong with my construction. There is also no room left where maybe the plastic bottom and cover of the case can be put together.
