How to persist robot data through a reboot
It is often needed to persist some robot data beyond reboots. The GoPiGo3 API uses the file gpg3_config.json for this purpose.
For each of my robots, I use the same concept and have a package to encapsulate and marshal access to my robot’s file.
# file:  daveDataJson.py
# Serialize data values to /home/pi/GoPi5Go/daveData.json
# (running ./daveDataJson.py will create the file)
# Methods:
#    saveData(dataname, datavalue, logit=False)   # adds datanaem:datavalue to rosbotData.json file
#    getData(dataname=None)      # either returns dictionary with all values, or just value of passed name
#    delData(dataname)           # delete item from rosbotData.json
#    printData()                 # prints contents of rosbotData.json
Example from Carl:
   lastDocking  :  ---- Docking 4573 completed  at 8.1 v after 2.6 h playtime
   chargeCycles  :  4573
   lastDismount  :  ---- Dismount 4573 at 10.9 v after 2.5 h recharge
   dockingState  :  1
   chargingState  :  1
   chargeConditioning  :  0
   lastDismountTime  :  2024-04-15 06:47:03
   lastRechargeDuration  :  2.5
   newBatterySetDate  :  2023-03-21
   newBatterySetAtDocking  :  3652
   newBatterySetAtLifeHours  :  36810.9
   newBatterySetDesc  :  8x Eneloop White 2000 mAh NiMH AA cells
   lastDockingTime  :  2024-04-15 04:15:21
   lastPlaytimeDuration  :  2.6
and a utility for command line editing the datafile
pi@GoPi5Go:~/GoPi5Go/ros2ws $ ../utils/mod_daveDataJson.py
daveData.json contents:
   lastDocking  :  ---- GoPi5Go-Dave ROS 2 Docking 1024 : success at battery 10.1v after 2.8 h playtime
   chargeCycles  :  1024
   lastDismount  :  ---- GoPi5Go-Dave ROS 2 Undocking, Charge Current 99 mA   12.1v after 2.6 h charging
   dockingState  :  undocked
   chargingState  :  discharging
   lastDismountTime  :  2024-09-18 09:09:12
   lastRechargeDuration  :  2.6
   newBatteryDate  :  2024-04-19
   newBatteryAtDocking  :  416
   newBatteryAtLifeHours  :  694
   newBatteryDesc  :  TalentCell YB1203000-USB 12v 3000mAh
   lastDockingTime  :  2024-09-18 06:33:20
   lastPlaytimeDuration  :  2.8
key: lastDocking :  ---- GoPi5Go-Dave ROS 2 Docking 1024 : success at battery 10.1v after 2.8 h playtime
Keep value "---- GoPi5Go-Dave ROS 2 Docking 1024 : success at battery 10.1v after 2.8 h playtime " y/n? y
key: chargeCycles :  1024
Keep value "1024" y/n? n
Enter New Value (without quotes): 1024
Use value "1024" y/n? y
   Saved chargeCycles: 1024
To use it:
import daveDataJson
chargeCycles = int(daveDataJson.getData('chargeCycles')) + 1
daveDataJson.saveData('chargeCycles', chargeCycles)
Ideally, error handling should be used…
I probably should have named it “robotDataJson.py” and the file “~/robotData.json” so it could have been reused more easily.
That’s an idea I’ve been toying with myself, once I get to the point where I need persistent data. :wink:
