Is there a way to check if the GoPiGo motors are actually running, if the car is driving?
There is a way to read the wheel encoders, (which I don’t remember). If the encoder values are changing, the wheels are moving.
You will have to do a search for the easygopigo libraries on-line as there are functions that return the encoder values.
Thanks a lot!
Yes, looking through the code I find that gopigi.enc_read(0) and gopigo.enc_read(1) read the wheel encoders.
def get_motor_status(self, port):
Read a motor status
Keyword arguments:
port -- The motor port (one at a time). MOTOR_LEFT or MOTOR_RIGHT.
Returns a list:
flags -- 8-bits of bit-flags that indicate motor status:
bit 0 -- LOW_VOLTAGE_FLOAT - The motors are automatically disabled because the battery voltage is too low
bit 1 -- OVERLOADED - The motors aren't close to the target (applies to position control and dps speed control).
power -- the raw PWM power in percent (-100 to 100)
encoder -- The encoder position
dps -- The current speed in Degrees Per Second
if port == self.MOTOR_LEFT:
message_type = self.SPI_MESSAGE_TYPE.GET_MOTOR_STATUS_LEFT
elif port == self.MOTOR_RIGHT:
message_type = self.SPI_MESSAGE_TYPE.GET_MOTOR_STATUS_RIGHT
else:
raise IOError("get_motor_status error. Must be one motor port at a time. MOTOR_LEFT or MOTOR_RIGHT.")
return
Is that an old GoPiGo? The current GoPiGo3 API for encoders is:
def get_motor_encoder(self, port):
Read a motor encoder in degrees
Keyword arguments:
Returns the encoder position in degrees
message_type = self.SPI_MESSAGE_TYPE.GET_MOTOR_ENCODER_LEFT
message_type = self.SPI_MESSAGE_TYPE.GET_MOTOR_ENCODER_RIGHT
else:
raise IOError("Port(s) unsupported. Must be one at a time.")
return 0
encoder = self.spi_read_32(message_type)
if encoder & 0x80000000:
encoder = int(encoder - 0x100000000)
return int(encoder / self.MOTOR_TICKS_PER_DEGREE)
I have the old one, GoPiGo2, bought in 2017.
In that case, to tell if motors are running use the read_motor_speed() API:
def read_motor_speed():
write_i2c_block(read_motor_speed_cmd, [unused,unused,unused])
try:
s1=i2c.read_8()
s2=i2c.read_8()
except IOError:
return [-1,-1]
return [s1,s2]
