Is there a way to do this without the need to completely flash the SD card with the new OS? I can’t find any way to do this.
Is there like a sudo apt-get install command or something?
Hi @esper2142,
You can upgrade your Raspbian Jessie to Raspbian for Robots following the instructions given here. However, I would like to, let you know that this process is time consuming and it might take an hour or more to complete. Also we might not be able to support a lot with this process because we have customized this process to work with our images.
If you wish, you can download our image directly from here or you can buy our SD card with Raspbian for Robots from here.
-Shoban
