I forgot to shut down my GoPiGo3, and it became not to connect to the server
Hi, I use the GoPiGo3 robot in my research.
I forgot to shut down my GoPiGo3, and it lost the power and then turned off. After trying to turn on with charged vatteries, it became not to connect to the server.
What should I do to connect again?
Is there a lot of customized code/scripts in your install?
It might be faster to burn a new image and copy the changes over than to fuss around with troubleshooting.
This all depends on the O/S you’re using. Care to tell us? It might make a difference.
How is it set up?
What are you trying to accomplish?
With regards to power, when my 'bot is on the bench, just being used to write and test code, I plug in a filtered +12v wall supply that can handle 3, maybe 4 amps. You may not need that much, but having headroom for current/power draw spikes is always a good idea.
Thank you for replying.
I tried to connect it to the server just now, the connection was succeeded!
